A doubt regarding saturation mode of BJT
The discussion revolves around the saturation mode of bipolar junction transistors (BJTs), specifically addressing the conditions under which both the emitter-base and base-collector junctions are forward biased. Participants explore the implications of voltage levels across these junctions and the resulting current flow.
  • Devanand T questions why the voltage across the base-collector junction is less than the typical 0.7V required for forward biasing, given that the collector-emitter voltage (Vce) is 0.2V in saturation.
  • Another participant suggests that 0.7V is an approximation and provides a more precise equation for the base-emitter voltage (V_{BE}), indicating that the base-collector junction also follows a similar relationship.
  • Devanand T reiterates the initial question about the base-collector junction voltage and notes that it is not reverse biased, but does not imply significant current flow through the junction.
Participants express differing views on the voltage levels required for forward biasing the base-collector junction, and there is no consensus on the implications of these voltage levels for current flow.
The discussion includes assumptions about the behavior of silicon p-n junctions and the application of Kirchhoff's voltage laws, but does not resolve the underlying questions regarding current flow and voltage levels.
dexterdev
Hi all,
I have a doubt regarding saturation mode of BJT. Saturation occurs when both emitter-base junction and base-collector junction gets forward biased. For forward biasing a silicon p-n junction only 0.7V is needed. So is for emitter-base junction. But not for base-collector junction. Because we know at saturation voltage across collector and emitter Vce is 0.2V. Using Kirchoff's voltage laws the voltage at base-collector p-n junction is less than 0.7V. Why is it lesser?
-Devanand T
0.7V is only an approximation.The more exact equation is:
[tex]V_{BE}=V_T\; \ln [\frac {I_c}{I_s}][/tex]
The Vbc diode obey the same equation. Actually I am working with transistors of Ic at 50uA range and the measured Vbe is about 0.5V!
dexterdev said:
Hi all,
-Devanand T
No one said there is heavy current flow from B-C. It's just not reverse biased. For an NPN, VBC = +0.5v is definitely a bias in the forward direction. But does not correspond to significant current flow through a silicon diode.
thankyou for your replies
