Finding Largest N for n^5-5n^3+4n Divisibility
  • Thread starter Thread starter ehrenfest
    Divisibility
ehrenfest
[SOLVED] larson 3.3.19b
What is the largest number N for which you can say that n^5-5n^3+4n is divisible by N for every positive integer N.
EDIT: change the last N to n
I have just been plugging in things for n and seeing what happens. If n=N-2,N-1,N,N
+1,N+2, then n^5-5n^3+4n is divisible by N because -2,-1,0,1,2 are the roots of that equation. If n=N+3, we get that 120 = -120 must equal 0 mod N. So, N=3 is a lower bound. So N must be a factor of 120. Should I just keep keep plugging in numbers for n and setting them equal to 0 mod N? It seems like that will give me a solution but that won't prove that this particular N works for all values of n.
I suppose you meant to say "What is the largest number N for which you can say that n^5-5n^3+4n is divisible by N for every positive integer n."
Now, n^5-5n^3+4n=(n-2)(n-1)n(n+1)(n+2) is the product of 5 consecutive integers hence divisible by 5!=120. I guess this is what you said, but I didn't really follow your reasoning. Next note that for n=3, the expression is 120.
Very nice! I was just beating around that solution...I just could quite hit it on the head.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
