Laser in underwater lidar application?
The discussion centers on the output beam diameter of microchip pulsed lasers for underwater lidar applications, suggesting it could be represented as \pi/e or potentially another value. The participants question the meaning of "e," debating whether it refers to the charge or the exponential constant. Additionally, there are inquiries about the appropriate polarization and output power specifications for pulsed laser sources in underwater environments. The conversation highlights the complexities and uncertainties in defining these parameters for effective lidar use. Overall, the topic emphasizes the need for further clarification and research in underwater lidar applications.
vani
what can be the output beam diameter for microchip PULSED laser in underwater lidar application?
Science news on Phys.org
I do not think that an answer exits for the given information.
It can be \pi/e.
It can be something else too.
laser
what does e specify?e charge or exp const?
what type of polarization&output power for pulsed laser source can be used in lidar application under sea?
Thread 'A quartet of epi-illumination methods'
Well, it took almost 20 years (!!!), but I finally obtained a set of epi-phase microscope objectives (Zeiss). The principles of epi-phase contrast is nearly identical to transillumination phase contrast, but the phase ring is a 1/8 wave retarder rather than a 1/4 wave retarder (because with epi-illumination, the light passes through the ring twice). This method was popular only for a very short period of time before epi-DIC (differential interference contrast) became widely available. So...
I am currently undertaking a research internship where I am modelling the heating of silicon wafers with a 515 nm femtosecond laser. In order to increase the absorption of the laser into the oxide layer on top of the wafer it was suggested we use gold nanoparticles. I was tasked with modelling the optical properties of a 5nm gold nanoparticle, in particular the absorption cross section, using COMSOL Multiphysics. My model seems to be getting correct values for the absorption coefficient and...
