Laser Modulation: Why Do We Need Bias and Modulation Currents?
  • Thread starter Thread starter fuyejun
    Current Laser
A laser diode requires a bias current to turn on before it can be modulated for data transmission. The bias current ensures the laser operates in a suitable range for effective modulation, which can be amplitude modulated to achieve specific modulation depths. There are two types of modulation: direct and external. In direct modulation, both bias and modulation currents are necessary to create a well-defined data pulse shape, while in external modulation, the laser operates as a continuous wave without a modulation current. Understanding these currents is crucial for optimizing laser performance in communication applications.
fuyejun
Hi:
I confused about the follow things, why people say a laser has bias current and modulation current. why a laser has modulation current?
fuyejun said:
Hi:
If you mean in the context of a laser diode, you need to turn it on (with some DC bias current), before you can modulate it (say, amplitude modulate it to some modulation depth) with information.
Modulation depth or "index": http://en.wikipedia.org/wiki/Amplitude_modulation#Modulation_index
There is more to modulating a laser than just 'turning it on and off' if you want to get the best result (i.e. producing a good data pulse shape). It is, essentially, a pretty non-linear device and I think the bias current is just a contribution towards providing it with a suitable driving waveform to produce a reasonably shaped modulation 'envelope'.
I read it from a book, there 2 kind of modulation, direct modulation and external modulation,
so I think when use direct modulation such 2 currents should be concerned ,bcs, it add "ONE" at "ZERO" current.
In external modulation, laser act as a CW (continuous wave) so there is no Modulation current.
But, above issues is what I think about,If there are wrong pls,tell me. Thanks a lot .:confused:
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
