Latent Heat + Specific Heat Problem
3 replies · 2K views
yaylee
Suppose molten (liquid) lead, mass ml = 9.83 kg, is at its melting point. The lead is poured into water of mass mw = 585 g and initial temperature Tw = 16.2 C. Find mwb, the amount of the water that boils.
NOTE: Reaching the boiling point is not enough; the question asks for the amount of water that vaporizes as well.
ASSUME: no water evaporates; it only vaporizes at the boiling point.
Constants: M.P Lead = 327 C, MP Water = 100 C
Latent Heat Lead = 33 kJ/kg
Latent Heat Q = mL
Specific Heat Eq'n: Q=mcΔT
mL + mcΔT = mcΔT + mL
9.83 kg (33 kJ/kg) + 9.83 kg(0.130 kJ/kg)(327C - 100C) = 0.585(4.186)(100 -16.2) + m(2260 kJ/kg)
Solving for m, we get m = 0.215 kg.
Did I go wrong in my reasoning here? Many thanks in advance for your help!
Your equation looks good to me. But I don't get the same numerical answer.
What do you get when you plug and chug in the values? I worked on the similar type of problem, and I got stuck on it from using that equation.
I get about 0.181 kg. What do you get for the numerical value of the left side of the equation? What do you get for the simplified form of the right side?
