Lakshya
- 71
- 0
Law of conservation of energy wrong??
a problem...pls check..
imagine there's a horizontal planeA bove which the effects of gravity are not felt. any object above the plane just floats and gravity has no influence on it.
now take a chain(for e.g:made of small steel ring) of length hundred metres above the planeA and arrange it so that its in a heap just above the planeA. but take care the chain is not entangled and should be easy to stretch along its length.
now pull the lower end of the thread below the planeA and the chain runs down like a single thread and hits the ground and as links pull down on the ones they are linked to , the whole length of the chain will run like a thread and hit the ground in some time. now take planeA is 20metres above the ground surface. the terminal velocity of links when they hit ground will be around 14 metres .
now consider hundred metres of the chain weighs 100 units. the potential energy of the chain just above the planeA will be m*g*h =100 *9.8*20
=19600 units.
but kinetic energy recovered would be 1/2 * m * v*v = 0.5 * 100* 14 *14 = 9800 units. so in this method only half the energy is recovered hence violating the law of conservation of energy.
SIMPLY PUT, THERES DIFFERANCE IN ENERGY RECOVERED WHEN U TAKE 100 METRES OF CHAIN TO HEIGHT OF 10 METRES AND DROP IT AS WHOLE TOGETHER THAN WHEN YOU ARRANGE IT SO THAT IT RUNS DOWN LIKE A THREAD , EACH LINK PULLING DOWN ON THE OTHER LINK IT IS CONNECTED TO...
now what will the terminal velocity be when the planeA is above 40 metres...?
i guess its around 19.6m/s instead of 28m/s...
ur thoughts pls correct me if I am wrong...
=19600 units.
