Fortran Program for Least Squares Fit of Data
In summary, the conversation is about creating a Fortran program to read data from a file and calculate the gradient and intercept of a best fit line. The code provided by one person is able to compile and run, but the output values are incorrect. The person asks for help and receives guidance from another person. The issue is resolved by making a minor adjustment to the code.
Bravus
23
(The usual format doesn't really fit this question, so I hope you won't mind if I set it up slightly differently)
The task is to make a Fortran program that will read in a given set of data from a file, stopping when it reaches the end, and calculate the gradient and intercept of a best fit line.
Here's my source code:
! Least Squares Fit program
! David Geelan, 2012 - Code free to use with acknowledgment
!23456
PROGRAM Least
IMPLICIT NONE
REAL :: E,a,a1,a2,b,x,y ! Same variables as worksheet
REAL :: sigmax, sigmay, sigmaxy, sigmax2 ! Sum variables
INTEGER :: i,n,IO ! Counting variables
! Open input file for reading
n=0 ! Initialise n
! Initialise all sum variables
sigmax=0
sigmay=0
sigmaxy=0
sigmax2=0
OPEN(unit=8,file="ws08_leastsquaresfit.dat",action='read')
100 FORMAT (1ES8.1,1X,1ES8.1)
DO
READ (8,100,IOSTAT=IO) x,y
IF (IO<0) EXIT
IF (IO>0) THEN
STOP "Something's up with the data"
END IF
n=n+1
sigmax=sigmax+x
sigmay=sigmay+y
sigmaxy=sigmaxy+(x*y)
sigmax2=sigmax2+x**2
WRITE (6,*) n,x,y,sigmax,sigmay,sigmaxy,sigmax2
END DO
a1=(n*sigmaxy)-(sigmax*sigmay)
a2=(n*sigmax2)-(sigmax)**2
a=a1/a2
b=(sigmay-(a*sigmax))/n
WRITE (6,*) a,b
REWIND(unit=8) ! Reset data file to start for reading
E=0 ! Initialise E
DO
IF (IO<0) EXIT
IF (IO>0) THEN
END IF
E=E+(y-(a*x)+b)**2
END DO
WRITE (6,*) 'For this model, a=',a,', b=',b
WRITE (6,*) 'Average square error=',E/n
CLOSE(unit=8) ! Close input file
END PROGRAM Least
It compiles and runs, and even outputs values... but they're not the right size! No idea what is going wrong. I set it to output the variables at each iteraction, and here's the full output when it's run:
bravus@bravus-VirtualBox:~/ws08_leastsquaresfit$ Least.exe
1 20.000000 3.0000000 20.000000 3.0000000 60.000000 400.00000
2 22.000000 4.0000000 42.000000 7.0000000 148.00000 884.00000
3 24.000000 4.0000000 66.000000 11.000000 244.00000 1460.0000
4 26.000000 5.0000000 92.000000 16.000000 374.00000 2136.0000
5 28.000000 6.0000000 120.00000 22.000000 542.00000 2920.0000
6 31.000000 8.0000000 151.00000 30.000000 790.00000 3881.0000
7 33.000000 7.0000000 184.00000 37.000000 1021.0000 4970.0000
8 34.000000 9.0000000 218.00000 46.000000 1327.0000 6126.0000
9 37.000000 8.0000000 255.00000 54.000000 1623.0000 7495.0000
0.34444445 -3.7592595
For this model, a= 0.34444445 , b= -3.7592595
Average square error= 56.968864
The instructor said the error should be at or less than one, so clearly something is badly wrong.
Should the formulae for a (which I broke into 2 steps for clarity) and b be inside the loop and iterated up, rather than working with the sums after the loop finishes?
Any help and hints gratefully received!
http://www.bravus.com/formulae.jpg
Thanks but never mind: a and b were being calculated correctly (I was misled by something else), and E just needed an extra set of brackets to sort the calculation order.
FAQ: Fortran Program for Least Squares Fit of Data
1. What is a least squares fit in Fortran?
A least squares fit in Fortran is a statistical method used to find the best-fit line or curve for a set of data points. It minimizes the sum of the squared differences between the actual data points and the fitted line or curve.
2. How is a least squares fit calculated in Fortran?
In Fortran, a least squares fit is calculated using the "linear least squares" algorithm, which involves finding the values of the slope and intercept of the best-fit line that minimizes the sum of squared differences. This is typically done using matrix operations and the least squares formula.
3. What types of data can be fitted using least squares in Fortran?
Least squares fit in Fortran can be used for both linear and nonlinear data. For linear data, a straight line is fitted, while for nonlinear data, a curve is fitted. It can also be used for multivariate data, where there are multiple independent variables.
4. What are the advantages of using least squares fit in Fortran?
One advantage of using least squares fit in Fortran is that it is a widely used and well-understood method for finding the best-fit line or curve for a set of data points. It also allows for the incorporation of measurement errors, making it a more accurate method than simply fitting a line or curve through the data points.
5. Can least squares fit in Fortran be used for large datasets?
Yes, least squares fit in Fortran can be used for large datasets. Fortran is a high-performance language, making it well-suited for handling large amounts of data. However, for very large datasets, it may be necessary to use parallel processing techniques to improve performance.
