Is A Full Rank Equivalent to an Overdetermined System?
A full rank matrix does not necessarily imply that the system is overdetermined. An overdetermined system, characterized by more equations than unknowns, can have a full rank matrix but may not always have an exact solution. The statement from the book highlights that a full column rank matrix often leads to no exact solution for Ax=b. Therefore, while full rank is a common feature of overdetermined systems, they are not equivalent. Understanding this distinction is crucial for solving such systems effectively.
Niles
Hi
If I am dealing with an overdetermined system Ax=b, then I can (assuming A has full rank) find the unique approximative solution by least squares.
Now, in my book it says that: "For a full column rank matrix, it is frequently the case that no solution x satisfies Ax=b exactly". I assume the book is saying that A having full rank is equivalent to it being overdetermined.
Is that always the case?
Niles.
That is not always the case, I found out.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
