Lebesgue-integrable continuous function with no limit at infinity
  • Level: Graduate
  • Thread starter Thread starter AxiomOfChoice
    Function
8 replies · 3K views · last reply
AxiomOfChoice
...satisfies the following conditions:
(1) Is continuous on [itex][1,\infty)[/itex], and
(2) Does not have a limit as [itex]x\to \infty[/itex].
Apparently, such a function [itex]f(x)[/itex] exists, but I cannot think of an example for the life of me. Remember: The function must also satisfy
[tex] \int_1^\infty |f(x)|dx < \infty,[/tex]
where "[itex]\int[/itex]" is the Lebesgue integral.
Can you think of a Riemann-integrable function f such that:
  • Max(f) = 1
  • Min(f) = 0
  • The integral over all of R is a (a is a previously chosen positive real number
  • Max(f) = 1
  • Min(f) = 0
Of course. How about
[tex] f(x) = \begin{cases}<br /> 1, & x \in [0,a],\\<br /> 0, & \text{otherwise}.<br /> \end{cases}[/tex]
On the line [tex][1,\infty)[/tex], at each integer point n, draw an isoceles of height [tex]2^n[/tex] and with base width [tex]4^{-n}[/tex]. Let the function be the curve of these isoceles when they occur, and 0 when they don't. This function is obviously continuous, and
[tex]\int^{\infty}_1 |f(x)| dx = \sum_{n=1}^{\infty} \frac{2^{n}4^{-n}}{2}= \frac{1}{2}\sum_{n=1}^{\infty} \frac{1}{2^n} = \frac{1}{2}[/tex]
However, the function has no limit as [tex]x \to \infty[/tex]. As an extra bonus it is not even bounded.
Jarle, some of your triangles overlap, but the basic principle still works.
Is it possible to find a [itex]C^\infty[/itex] function that satisfies the OP's criteria? Yes, I see it is possible after just writing that...
How about an analytic function that satisfies the criteria? For that, I'm not sure...
Ben Niehoff said:
Jarle, some of your triangles overlap...
I don't see why this is so. Can you give an example of two overlapping triangles?
Also, what do you mean by "OP's criteria?"
Perfect. I feel like a fool for not having thought of this myself. Thanks!
I feel like this is one of those questions that is either "obviously yes" or "obviously no", but I don't know which. :biggrin:
My first inclination is a function like
[tex]f(x) = \exp\left(\frac{x}{2} \log( \sin(x)^2 ) \right)[/tex]​
which, on R, simplifies to
[tex]|\sin x|^{x}[/tex]​
or maybe replace x/2 with something even faster growing.
I haven't ground through the analysis to see if this actually has a finite integral.
However, http://www.wolframalpha.com/input/?i=Integrate[Exp[Exp[x]/2+Log[Sin[x]^2]],+x]
Is that analytic? Well, this one is more obviously so: http://www.wolframalpha.com/input/?i=Integrate[Exp[Exp[x]/2+Log[(1/2)+++(1/2)Sin[x]^2]],+x]
or maybe replace x/2 with something even faster growing.I haven't ground through the analysis to see if this actually has a finite integral.However, http://www.wolframalpha.com/input/?i=Integrate[Exp[Exp[x]/2+Log[Sin[x]^2]],+x]Is that analytic? Well, this one is more obviously so: http://www.wolframalpha.com/input/?i=Integrate[Exp[Exp[x]/2+Log[(1/2)+++(1/2)Sin[x]^2]],+x]
How about replacing the triangles in the given solution to the original problem with Gaussians?
[tex]f(x) = \sum_{n=1}^\infty \frac{2^n}{\sqrt{2\pi}} \exp\left[-\frac{(x-n)^2}{2\sigma_n^2}\right][/tex]
where [itex]\sigma_n = 4^{-n}[/itex]?
It's possible this isn't analytic since we're summing an infinite number of terms, but it'd be the first thing I'd try (if I felt like trying to prove/disprove things like analyticity). (Of course, even if analyticity is proved doing the resulting integral wouldn't be too fun - at least on the [1,infinity) interval. (-infinity,infinity) wouldn't be so bad. ;))
