Length and Value of KE Question. Please Check Answer
  • Thread starter Thread starter cbrowne
    Length Value
The discussion focuses on calculating the total length and kinetic energy of an object while considering uncertainties. For the combined length of two wooden pieces, the total is determined to be 2.01 ± 0.0224 m. The kinetic energy of the object, with mass 2.3 ± 0.1 kg and speed 1.25 ± 0.03 m/s, is calculated as 1.80 ± 0.0853 J. It is emphasized that uncertainties should be reported with appropriate significant digits, and the method for calculating kinetic energy uncertainty requires careful consideration of relative uncertainties. Accurate handling of uncertainties is crucial for reliable results in physics calculations.
cbrowne
1) Two pieces of wood are glued together to form a long stick. The length of the
first piece is L1 = 0.97 ± 0.02 m, and the length of the second piece is
L2 =1.04 ± 0.01 m. What is the length (including uncertainty) of the stick?
2) An object of mass m = 2.3± 0.1 kg , is moving at a speed of
v =1.25 ± 0.03 m/s . Calculate the kinetic energy ( KE = 1/2 mv2 ) of the object.
What is the uncertainty in the calculated value of KE ?
L1+L2 = .97 + 1.04 ± Δuncertainty
Δu = sqrt(u12 + u22 + ...) = √ (.02^2+.01^2) =.0224
L1+L2 = 2.01 ± 0.0224m
KE=0.5mv2 ± Δ u= 1.80±Δ
Δu=dX/X = sqrt( (dA/A)2 + (dB/B)2 +...) =
=dX/1.80 = sqrt( (0.1/2.3)2 + (0.03/1.25)2 )
=√.002466*1.80
=.0853
KE=1.80±.0853J
Giving your uncertainty with more significant digits than the precision of results is not exactly the best way to handle it in 1).
In 2) you need to add the square of the relative uncertainties of the V twice to account for the V2 and then add the square of the m uncertainty and then take the square root.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
