How Can You Calculate the Length of a Ramp Based on Sliding Time and Friction?
The discussion focuses on calculating the length of a ramp based on the sliding time of a concrete block and the coefficient of kinetic friction. The block slides down a ramp inclined at 37 degrees, taking 2 seconds to reach the ground, with a kinetic friction coefficient of 0.25. The acceleration was calculated to be 6.35 m/s², leading to a final velocity of 12.7 m/s and a ramp length of 12.7 meters. Participants emphasized the importance of accurate free-body diagrams and trigonometric relationships in solving the problem correctly.
  • Understanding of Newton's laws of motion
  • Knowledge of free-body diagrams
  • Familiarity with trigonometric functions in physics
  • Basic algebra for solving equations
  • Review the principles of free-body diagrams in physics
  • Study the application of trigonometric functions in inclined plane problems
  • Learn about the effects of friction on motion
  • Practice similar physics problems involving ramps and sliding objects
Students studying physics, particularly those focusing on mechanics, as well as educators looking for examples of inclined plane problems and friction analysis.
neongoats
You are passing a construction site on the way to physics class, and stop to watch for a while. The construction workers appear to be going on a coffee break, and have left a large concrete block resting at the top of a wooden ramp connecting one of the building's upper floors to the ground. As soon as their backs are turned, the block begins to slide and takes about 2 seconds to reach the ground. You wonder how long the ramp is. You estimate the ramp is at an angle of about 37* to the horizontal, and your physics book gives the coefficient of kinetic friction (uk) between concrete and wood as 0.25
a= F/m
vf=vi+at
vf^2=vi^2+2ax
I found that:
Fnety = Fn - Fgy = Fn - mgsin(37) = 0
Fn = mgsin(37)
Fnetx = Ff - Fgx = uk(mg)sin(37) - mgcos(37) = ma
a = uk(g)sin(37) - gcos(37)
a = .25(-9.8)sin(37) + 9.8cos(37)
a = 6.35 m/s^2
vf-vi = at
vf = 6.35(2)
vf = 12.7 m/s
vf^2 - vi^2 = 2ax
12.7^2 = 2(6.35)x
x = 12.7m
I don't understand how this is wrong?
Did you draw a free-body diagram?
Check your trig relations - the angle is measured from the horizontal.
Don't forget to define the x and y directions as part of your working.
I did draw a free body diagram and I believe my trig relations are correct.
After further digging I found nearly the exact same question http://courseweb.stthomas.edu/physics/academics/111/Brita/Spring%202012/Unit%202/GP6%20P11%20S12.pdf but when I calculate the velocity with their numbers I still get the wrong velocity?
Edit: As in their paper says vf = 2.5 m/s but I get 80.36 when I plug those exact same numbers into my calculator. Did they do it wrong or am I messing up my calculation somewhere?
a= .25(-9.8)sin(37) + 9.8cos(37)
I think you have mixed up your sines and cosines. You need a large, clear diagram to work on, or you probably will get these wrong.
Is the correct answer around 7.5 roughly?
Looking at your FBD: if you have theta as the angle of the ramp to the horizontal, and you have defined the +y axis to be upwards and perpendicular to the ramp, then the normal force to the ramp is ##\vec N = \hat\jmath mg\cos\theta##. You may need to redraw your diagram to see this.
15K
11K
