Length of Spring: How Can the Unstretched Length Be Determined?
  • Thread starter Thread starter ttiger2k7
    Length Spring
The discussion focuses on determining the unstretched length of a spring under a load of 400 N, with a spring constant of 800 N/m. The user successfully calculated the weight W as 62.8 N and the force in the spring as 281.712 N. They also measured a length of 1110 mm using the Pythagorean theorem, questioning its relevance to finding the unstretched length. The conversation includes considerations of using trigonometric functions and components to refine the calculations. Ultimately, the user confirmed they resolved the problem.
ttiger2k7
[SOLVED] Length of Spring
A load of weight 400 N is suspended from a spring and two cords that are attached to blocks of weights 3W and W as shown. Knowing that the constant of the spring is 800 N/m, determine (a) the value of W, (b) the unstretched length of the spring.
http://img406.imageshack.us/img406/472/13213uv7.jpg
F_{s} = -k x
I have already worked through part (a), getting 62.8 N for W and in the process I got 281.712 for the F_{s} of the system above.
Now from the picture above, I can figure that the length AB is 1110 mm using Pythagoreans. Whether that is relevant or not to figuring (b) out, I am not sure. I'm thinking that I need to find what the F_{s} would be if there were no forces acting on the spring.
F_{s} = -k x
I would look at the relevant equation and attempt to determine if it can be expanded to include initial and final values.
You can determine angles using SOH CAH TOA. From there you can use components to work out your answer more precisely.
double post...
Thanks, I got it!
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
