LHC Part 2: Commissioning - comments
  • Context: Insights
  • Thread starter Thread starter mfb
    Lhc
The discussion centers around the commissioning of the Large Hadron Collider (LHC), focusing on technical aspects such as beam dumps, radiation monitoring, vacuum levels, and power consumption during operation. Participants explore various components and operational challenges related to the LHC's functionality and safety measures.
  • Some participants inquire about the composition and design of the beam dumps, with details provided about materials used, cooling systems, and methods to manage heat during beam dumping.
  • Questions arise regarding the interaction of cosmic ray muons with protons in the beam pipes, with some participants noting the rarity of such collisions and the challenges of distinguishing these events from primary collision data.
  • Participants discuss the operational sounds of the LHC, noting that while cooling systems may produce noise, the beam itself does not, and there is uncertainty about any noise generated during beam dumping.
  • Concerns are raised about the power consumption of the LHC, with estimates provided for operational power needs and the necessity for coordination with external power grid operators.
  • Participants explore the frequency and conditions under which emergency beam dumps occur, with some noting that many dumps are precautionary rather than due to actual emergencies.
  • There is discussion about the vacuum levels maintained during operation, with specific pressure ranges mentioned, and the complexity of the vacuum systems highlighted.
  • False alarms from radiation monitors are acknowledged as a common issue, with some participants questioning the reliability of these systems and the implications for safety protocols.
Participants express a range of views on the operational aspects of the LHC, with some agreeing on the rarity of certain events while others raise concerns about safety and the implications of false alarms. The discussion remains unresolved on several technical points, particularly regarding the specifics of emergency protocols and the reliability of monitoring systems.
Limitations include the dependence on specific definitions of "emergency" regarding beam dumps, as well as the complexity of the vacuum systems and the potential for false alarms in radiation monitoring. These factors contribute to the nuanced understanding of operational safety and efficiency.
mfb submitted a new PF Insights post
Continue reading the Original PF Insights Post.
Greg Bernhardt said:
What are these special "special beam dumps" made of?
The primary absorber itself is a set of steel-encased, water-cooled carbon slugs, each about two feet across. Additional concrete and iron shielding surrounds this. When the beam is dumped, it is swept across the face of the carbon so that the load is spread around.
Large cylinders of graphite (7m long, 70cm diameter). Just shooting the beam into them would still melt them partially, so there are two additional tricks to spread the heat:
- the beam dump is at the end of a tunnel 750 meters long. That gives the beam some time to spread out.
- the beam gets extracted over a time of 100 microseconds (ring length divided by speed of light). During this time, deflection magnets change the direction of the beam, so different parts of the beam hit different parts of the graphite.
The whole beam dump is water-cooled and shielded with hundreds of tons of concrete and iron.
More details
Edit: didn't see Envelope's post, I was writing already.
I have some question after reading that thing about UFOs (catchy name)...
If in the ATLAS detector you can measure some cosmic rays muon background, what would stop the muons from entering the beam pipes while the experiment is ongoing? Wouldn't they interact with the highly energetic protons?
Nothing.
A single muon/proton collision is (a) incredibly rare and (b) negligible (just releases several TeV of energy).
At ground level, we have about 100 muons/(m2s). There are up to ~5*1014 protons in the machine. With a cross-section of ~100mb (probably too high), we get 1.6*10-5 collisions per year. Even without the shielding from the material above, it is unlikely that a collision happens within the lifetime of the LHC.
If you replace the protons by the whole ATLAS detector, you get many interactions - enough to use them for initial alignment (measuring the relative orientations of the detector components) until collision events come up.
Very cool. Does it sound like anything, when it's at full tilt? Or it it just cooling fans and ominous silence? How about when it dumps a beam? Also, when operating does it eat a lot of power.? If so is there a generation plant on-site, or do you have to coordinate with wider distribution grid operator? The tube tunnel would be deadly place to be under operation right?
There is no one close to the machine when it is operating, but I guess you would mainly hear the cooling systems (not so many fans, mainly liquid cooling). The beam itself does not make any sound.
Dumping it could induce some thermal stress in the beam dumps, no idea if that makes noise.
About 150 MW, plus 20 MW for the experiments.
CERN does not operate a power plant, so they certainly have to coordinate that with the grid operators. Most of the power consumption is permanent or with long ramping times, however.
Not necessarily. If nothing goes wrong the radiation is higher than normal, but most places should not be deadly (assuming you don't stay there for years). If something goes really wrong, in the worst case (which is very unlikely and never happened so far) it can kill you instantly.
As mfb pointed out, this is a very low probability (and recognizable) event. The bigger problem is that you get a cosmic ray interaction on top of another event, and the two get confused. Many of the ATLAS and CMS papers spend a good deal of ink explaining how such events are rejected. Fortunately, both experiments have large samples of cosmic rays (some are being collected right now) so they know from data how such events register in the detectors.
How often has a beam been emergency dumped so far? Was it always the radiation detectors that triggered this?
What is the vacuum level during operation? What size of vacuum production equipment is needed to maintain the high vacuum?
Depends on the definition of "emergency". Dumps due to safety issues in one of the systems are common. Sometimes (and especially during commissioning) the beams get dumped because they are not needed any more, or the machine has to be empty for the next test.
During regular data-taking, the beam gets dumped after ~10-15 hours of data-taking as the decreasing number of protons and beam quality make re-filling for a fresh run more attractive.
In the beam pipe: 10-8 to 10-9 Pa, or 13 to 14 orders of magnitude below atmospheric pressure, it depends on the position. There are other vacuum systems for insulation of the magnets and other parts.
The vacuum system is large and complex, see the technical design report for details.
About half of the store terminations are unscheduled. So "emergency" is maybe not the right word. Essentially, if anything looks even remotely wrong, the beam is dumped. That includes not just things like the radiation monitors going into alarm, but also things like the radiation monitors being turned off - if we go blind, even for a moment, the beam is dumped.
How many distinct radiation monitors are there, any idea? I'm trying to get an idea if false alarms would become a serious problem? Are very low false positive detectors needed? I hope no technician that has had a thyroid scan goes near the detectors. :)
False alarms are an issue (they are a very common reason for dumps), but not reacting to all alarms could give an even larger problem.
During operating there is no one in the accelerator tunnels. And that would be orders of magnitude too low to trigger radiation monitors.
That's a lot less power than I was expecting! About one large frame turbine's worth? A big smelter probably isn't much less than that. I guess it's a great example of the hard to grasp relationship between scales of size and energy involved with looking way back and "down" into stuff. I had been intuitively picturing staggering amounts of power, but the 2 cm tube, and that relatively run of the mill power consumption, has adjusted that a lot. Very interesting.
LEP in the same tunnel about 15 years ago needed more power: its beam lost ~20 MW to synchrotron radiation, and the dipole magnets to keep the beams on track were not superconducting.
The LHC accelerates protons with 2000 times the mass of electrons, that makes synchrotron radiation negligible.
The power needed to actually accelerate the protons is small: ~500 MJ over 20 minutes is just ~400 kW.
What kinds of interactions will they be looking for once data collection begins?
Proton-proton collisions can produce all known particle types (and hopefully some unknown types!), at the LHC many of them are more frequent than at every other accelerator. All those get studied - the Higgs of course, the top-quark, W and Z bosons of the weak interaction, heavy mesons and baryons with a bottom- or charm quark, together with studies of the strong interaction, the electromagnetic interaction, and so on. And searches for new particles, of course. At the end of 2015, the LHC will also collide lead nuclei with protons and lead nuclei with lead nuclei. The main focus there is on the strong interaction.
The experiments have lists of their publications:
ALICE
ATLAS
CMS
https://lhcb.web.cern.ch/lhcb/Physics-Results/LHCb-Physics-Results.html
And the smaller experiments:
LHCf
TOTEM[/size]
Thanks for replying. Why are lead nuclei used in particular?
It is the heaviest stable element and it has a high gas pressure when heated (which makes it easier to collect a nice group of ions closely together). Other experiments also used gold, uranium and a few other heavy elements. Uranium could be interesting as it is not spherical.
It's not just lead, it's Pb-208. This is a spherical nucleus, which is helpful in analysis, and it happens to be the only isotope that the CERN ion source can inject into the LHC. The LHC itself can handle pretty much any ion, but to get the ion into the LHC would require some reworking of the source first.
At one point, there was an unplanned connection between an electrical line and ground. ... The machine operators studied it in detail and then decided to take a risk: send a large current through this connection to burn it away.
To the LHC Machine Operators: Hope you guys are getting paid well. :bow:
  • Sticky
  • · Replies 16 ·
  • Sticky
  • Sticky
9K
  • · Replies 57 ·
16K
  • · Replies 33 ·
  • · Replies 69 ·
14K
  • · Replies 28 ·
