The Light Clock Problem: Resolving Observer Discrepancies
The discussion centers on the discrepancies in time perception between two observers, O and A, where O is stationary and A is moving at a constant velocity. A hears 10 ticks from her light clock, while O perceives A's clock ticking slower, resulting in only 5 ticks heard. The key point is that both observers do not have to agree on the number of ticks due to time dilation and the synchronization of their clocks. A's perspective reveals that O and O' have not synchronized their clocks correctly, leading to different interpretations of the same events. Ultimately, the resolution lies in understanding that time dilation affects their observations but does not imply one observer's clock is objectively slower than the other's.
Quarlep
Lets suppose there's two obsrver O observer is in rest and A is moving with a constant velocity. A observer has a light clock which every click it makes sound.So A observer sees everything normal. Let's suppose A observer heard 10 tics but O sees him moving so O observer will heard 5 tics.But both of them can't be true.
Which one is true ?
This is wrong. Both of them hear the same number of ticks. Just the delay between the ticks is longer for O.
Why not?
If ##N_A## is the number of ticks A hears and ##N_O## is the number of ticks that O hears then those are different quantities and there is no logical reason that they must be equal. You can certainly set up scenarios where they are, but you can also set up scenarios where they are not.
What you need to realize is that if neither observer accelerates, then you can't separate time dilation from the problem of clock synchronization.
Let's set observer O up with a partner, O' who is at rest relative to O, and a distance of 100 light-seconds (a light second is the distance light travels in one second). Observer A travels from O to O'. If A is traveling at 86.6% of the speed of light, then it will take her 115 seconds to get to O'. For simplicity of calculations, let's assume that the light clocks "tick" once per second. Here's the sequence of events from the point of view of both O and A
From the point of view of O
  1. Event e_1: O starts counting "ticks" of his light clock at the moment A passes by. A starts counting "ticks" of her light clock.
  2. Event e_2: O' starts counting "ticks" of his light clock. In O's frame, e_1 and e_2 are simultaneous (to arrange this requires synchronizing clocks, and knowing when A will pass O, but let's assume that has happened)
  3. Event e_3: A passes O'. According to O, this event happens 115 seconds after e_2. By this time, A has counted 57.5 seconds worth of "ticks" of her light clock, and O' has counted 115 seconds worth of "ticks". So O and O' conclude that A's light clock is "ticking" at 1/2 the rate of their light clocks.
So does that objectively mean that A is the one whose clock is running slower? No, because let's look at things from the point of view of A now. From A's point of view, O and O' have not correctly synchronized their clocks. From her point of view, O' starts counting 172.5 seconds BEFORE O does. So she sees the following sequence of events:
  1. Event e_2: O' starts counting ticks of his light clock.
  2. Event e_1: O and A pass each other, and both start counting ticks of their respective clocks. From A's point of view, this event happens 172.5 seconds after event e_2. So at this time, O' has already counted to 86.25 seconds (172.5 seconds have passed, but O' is counting at half the rate.
  3. Event e_3: A and O' reach each other. According to A, this event happens 57.5 seconds after event e_1 and a full 230 seconds after event e_2. So A has counted up to 57.5, while O' has counted up to 115 (half of the 230 seconds since he began counting).
MOVING CLOCKS In this section, we show that clocks moving at high speeds run slowly. We construct a clock, called a light clock, using a stick of proper lenght ##L_0##, and two mirrors. The two mirrors face each other, and a pulse of light bounces back and forth betweem them. Each time the light pulse strikes one of the mirrors, say the lower mirror, the clock is said to tick. Between successive ticks the light pulse travels a distance ##2L_0## in the proper reference of frame of the clock...
  • · Replies 34 ·
  • · Replies 25 ·
  • · Replies 46 ·
  • · Replies 88 ·
  • · Replies 25 ·
  • · Replies 65 ·
