Light Cone Distributions: Review by Eric Poisson, Ian Vega and Adam Pound
PLuz
Hello,
I have been reading the excellent review by Eric Poisson, Ian Vega and Adam Pound:http://relativity.livingreviews.org/Articles/lrr-2011-7/fulltext.html
In section 12, Eq.12.15, there's something that I don't quite understand. They write:
\delta_{\pm}\left(\sigma\right)=\theta_{\pm}\left(x,\Sigma\right)\delta\left(\sigma\right),
so they define the light cone Dirac Functionals \delta_{\pm} with the functional \delta (\sigma). But they don't define \delta (\sigma). I suppose they intend to define a Dirac distribution along the unique geodesic that links two points in space time, but the Synge world function is defined for space,time and null geodesics, how is \delta (\sigma) only restricted to the light cone?
(You might also want to look in section 13.2 where they generalize for curved spacetime)
Thank you and sorry if it's a silly question.
\delta (\sigma) is not restricted to the light-cone, the support of \delta (\sigma) is restricted to the light-cone. The support of a function is the closure of the set on which the function is non-zero.
Oh, yes, that makes more sense.
Altough, to clarify, if I have a base point x_1 and another point, say, x_2 \in I^+(x_1), how would one see \delta(\sigma) as a function of x_2?
I don't understand the argument of \delta, what should I visualize? x_3:=\sigma(x_1,x_2) it's a scalar, what does it mean \delta(x_3)?
Sorry if I'm being annoying. Thank you.
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
So, to calculate a proper time of a worldline in SR using an inertial frame is quite easy. But I struggled a bit using a "rotating frame metric" and now I'm not sure whether I'll do it right. Couls someone point me in the right direction? "What have you tried?" Well, trying to help truly absolute layppl with some variation of a "Circular Twin Paradox" not using an inertial frame of reference for whatevere reason. I thought it would be a bit of a challenge so I made a derivation or...
