A Einstein & Light Deviation: Compute w/o Schwarzschild Metric
e2m2a
How did Einstein compute the amount of light deviation due to the Earth's gravitational field when the Schwarzschild metric was not known yet?
He didn't get it right at the first try, in fact in his first calculations in 1908 he was off by a factor of 2. The correct result was obtained 1915 using the weak field approximation where all terms smaller than the order of 1/c³ were neglected, see http://home.fnal.gov/~syphers/Education/Notes/lightbend.pdf
Yukterez said:
He didn't get it right at the first try, in fact in his first calculations in 1908 he was off by a factor of 2. The correct result was obtained 1915 using the weak field approximation, see http://home.fnal.gov/~syphers/Education/Notes/lightbend.pdf
ok. Thanks for the reference.
http://mathpages.com/rr/s8-09/8-09.htm
Likes m4r35n357
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
