Lightning strikes a swimming pool
  • Thread starter Thread starter primarygun
    Lightning Swimming
If lightning strikes a swimming pool, the swimmer is at significant risk of injury due to the rapid transfer of electrical charge. While the pool may not create a complete circuit, the influx of charge can lead to a high current that affects the swimmer's body. The presence of ions in the water can amplify the effects of the electric field generated by the lightning strike. Therefore, even if the circuit isn't closed, the swimmer can still experience severe electrical shock. Ultimately, swimming during a lightning storm poses serious dangers.
primarygun
If a lightning strikes a swimming pool, what happens to me if I am swimming?
I think it is not a complete circuit, so I won't get enormous current.
But, will the sharing of excess charge too fast and I get hurt?
Science news on Phys.org
The same answer, if an electricity cable was connected from one end an electricity source and the other end was splashed in water..And u put ur bare leg into this water what will happen to u??
If water molecules can transmit the electiricity to ur leg, it'll transmit the charge of the lightning to ur whole body...
but
If it is not a complete circuit, I won't get hurt.
Nevertheless, lightning bring charges into the pool and my body will get the charge at a high rate resulting a large current?
An RC circuit with a battery isn't technically a closed circuit, but there's still current, if only for a while. If your swimming pool is electrolytic (which is almost certainly is), it will have ions that will be affected by the huge electric field. That is, yes, you will get hurt.
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
