Lim as x goes to a of sqrtx = sqrta
  • Thread starter Thread starter apiwowar
The discussion centers on the proof of the theorem stating that as x approaches a, the limit of sqrt(x) equals sqrt(a). It emphasizes the use of a constant c in the proof to ensure that epsilon is independent of x. This approach is crucial for establishing the relationship between epsilon and delta in the context of limits. The typical epsilon/delta proof requires demonstrating that for every epsilon, a corresponding delta can be found to satisfy the limit condition. Understanding the role of the constant c is essential for grasping the proof's mechanics and its implications for limits.
apiwowar
this is a theorem that has a proof. in the proof they use a constant c so that epsilon is not in terms of x when you go to prove it. can someone explain this proof and also how and why you get/use a constant c to prove this theorm?
Mathematics news on Phys.org
I would have to see this proof to explain it.
With the typical epsilon/delta proof of a limit, to prove that lim x->a f(x) = L you need to prove that for EVERY epsilon, a delta exists such that if a-delta < x < a+delta, then |f(x)-L| < epsilon.
epsilon is arbtrary and not in terms of x or anything else, and delta will be a funtion of epsilon that you will have to choose to make |f(x)-L| small enough.
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
