Limit below which we cannot detect light?
  • Thread starter Thread starter neopolitan
    Light Limit
The discussion centers on the limits of detecting light and electromagnetic radiation, particularly regarding frequencies below the light spectrum, such as ELF. Participants argue that while instruments have sensitivity limitations, it is possible to detect ELF signals, albeit with challenges related to signal strength and detector size rather than temperature. There is a consensus that while there may not be a theoretical lower limit to the frequencies that can be measured, practical constraints exist, particularly concerning amplitude detection. The conversation also touches on the implications of redshift and how it affects the detection of light from distant cosmic sources. Overall, the thread highlights the complexities of measuring low-frequency electromagnetic radiation and the ongoing advancements in detection technology.
neopolitan
Mentz114 said:
Are you saying there is no limit below which we cannot detect light ? That's just plain wrong. Our instruments are not infinitly sensitive. Already we have to cool the detectors to very low temperatures.
It was largely irrelevant to the thread where it originally appeared, but I think it is also largely wrong. I am pretty damn sure that we can detect all frequencies below the light spectrum at least down to the ELF radio spectrum - we might have problems with weak signals but not lowish frequencies. Admittedly you need a landmass as the detector (like a peninsular or a subcontinent), but it is technically feasible to detect an ELF signal.
Problems with detecting frequencies below ELF (below 1 hertz for example) would have nothing to do with the temperature of the detectors and more to do with the size of the detectors.
Is this wrong?
I don't think there is any transmitter in the universe that is moving fast enough to cause doppler shift down to below ELF, is there?
cheers,
neopolitan
Science news on Phys.org
ELF raditation also originates from terrestrial sources (thunderstorms), and is detectable with an antenna:
http://www-pw.physics.uiowa.edu/mcgreevy/
ELF is considered in the audio range- 100-11000 Hz. There's Schumann resonances which occur below 8 Hz, those are also detectable with specialized detectors. I don't know what the 'world record' is for lowest detected frequency.
Note there's a difference between lowest frequency and lowest amplitude. The lowest amplitude that can be detected corresponds with thermal noise, but there's some tricks (lock-in amplifiers) that can get down into the dirt somewhat.
What do you mean by amplitude? The intensity? Am I missing something?
Amplitude or intensity- yes. At low frequencies we can coherently detect the radiation (i.e. measure the phase), so the amplitude is measured. At high frequencies (optical), radiation is detected incohreently, so it's the intensity that's measured.
Mentz114 said:
Why not ? There are lots of things out there that you and I don't know about.
Please read this
en.wikipedia.org/wiki/Observable_universe
and this
en.wikipedia.org/wiki/Event_horizon
Ok. Done that.
I agree, the more we learn the more we get to know how little know. I guess a black hole could shift light to ELF frequencies, it's not what I am currently looking at. But do you not wonder why scientists look for x-ray emissions when seeking black holes?
cheers,
neopolitan
Is this wrong?
cheers,
neopolitan
The term "light" refers to a certain set of frequencies, i.e. those which are detectable by the human eye, all of which are measureable. ELF is not considered to be light since the frequency is outside of the visual range.
If you are actually asking about the frequency of electromagnetic radiation then, classically, there is no theoretical lower or upper limit to what can be measured. We may simnply not have instruments that can measure certain wavelengths but that could change in the near future.
Best wishes
Pete
I'm sure many of us have measured some 0 Hz (DC) fields in our time :-p.
Claude.
The band of frequencies we have trouble detecting is between the upper end of radar and below infrared.
Generally, the terahertz range.
Until recently there were no detectors at all for this area.
Claude.
Erm.. yes. But DC current is not an electromagnetic field, which is what the OP is referring to, I believe.
I'd like to point out that the quote made by the OP ( something I said in another thread) was in the context of the cosmic expansion, and refers to the event horizon ceated by the expansion. The largest red-shift observed is about 7.
An earlier thread
https://www.physicsforums.com/showthread.php?t=114745
From Wiki -
The luminous point-like cores of quasars were the first "high-redshift" (z > 0.1) objects discovered before the improvement of telescopes allowed for the discovery of other high-redshift galaxies. Currently, the highest measured quasar redshift is z = 6.4,[46] with the highest confirmed spectroscopic redshift of a galaxy being IOK-1[47], at a redshift of 6.96, and the highest lensed galaxy redshift being z = 7.0[48] while as-yet unconfirmed reports from a gravitational lens observed in a distant galaxy cluster may indicate a galaxy with a redshift of z = 10.
It was also the improvement in IR detector technology that drove this research forward.
So radio astronomy ( so far) doesn't come into it. I don't know why the OP won't acept the simple truth that there is a lower limit of frequency and/or amplitude that our instruments will probably never overcome.
But is it a specific/hard limit or just an asymptote? The limit on amplitude, for example, is single-digit photons per second over an area determined by how big the detector is. So that means we can get arbitrarily close to zero based almost soley on how much effort we decide to put into building big detectors.
I did actually ask this
Perhaps I was insufficiently clear, since we were talking about telescopes and light, I assumed the doppler shift was of light. EMR which is already prettly low can be shifted lower, to below ELF, but I meant light - there is no transmitter moving fast enough (relative to us) to doppler shift visible light down to below ELF. What you say here confirms that since the relevant equation is (rearranged from wiki, to make it easier to write here)
z + 1 =(frequency emitted)/(frequency observed)
Using a frequency emitted in the middle of green (575 terahertz) and z=10 (the highest as yet unconfirmed value that you quoted), this gives us
11 = 575 tHz / (frequency observed)
frequency observed = 575 tHz / 11 = 52 tHz
This is at the lower end of the http://en.wikipedia.org/wiki/Terahertz_radiation" and it is difficult to detect in our atmosphere, due to absorption. As wiki indicates, it was challenging to detect at all until the 1990s. Challenging, not impossible.
If you got an even greater redshift, enough to push the frequency even lower, it is actually easier to detect the radiation, as you get into microwaves, and even radiowaves.
However, the values of z you are talking about here are magnitudes higher than observed.
Frequency, no, amplitude, yes. But as Russ Watters pointed out, with the will we could feasibly make more and more accurate detectors, until it gets ridiculous and you are devoting planet sized detectors to detect weak (low amplitude) signals, which probably will be drowned out anyway in all the stronger - local - signals around due to the frequency spread associated with square waves (emitted for example from the equipment you have to use to build the detector itself).
Weak signals = low amplitude. Perhaps I should have made that more clear, but I thought it was obvious at the time.
cheers,
neopolitan
