When n is large, the numerator is much larger than the demoninator, so the limit is 0, surely?
#3
mg0stisha
225
Are you sure? When n is small, the numerator is larger, but when n gets large, the denominator is actually larger.
EDIT: Next time, put a question like this in the 'Homework Questions' section. That's where it should be, and you'll also probably get a response faster that way.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
Hello,
This is the attachment, the steps to solution are pretty clear. I guess there is a mistake on the highlighted part that prompts this thread.
Ought to be ##3^{n+1} (n+2)-6## and not ##3^n(n+2)-6##. Unless i missed something, on another note, i find the first method (induction) better than second one (method of differences).
