Is the Difference Between \Delta V and dV Very Small for Small \Delta x?
  • Thread starter Thread starter GunnaSix
    Delta Limit
GunnaSix
Let V=x^3
Find dV and \Delta V.
Show that for very small values of x , the difference
\Delta V - dV
is very small in the sense that there exists \varepsilon such that
\Delta V - dV = \varepsilon \Delta x,
where \varepsilon \to 0 as \Delta x \to 0.
dV = 3x^2 dx
\Delta V = 3x^2 \Delta x + 3x (\Delta x)^2 + (\Delta x)^3
I worked it down to
\varepsilon = 3x \Delta x + (\Delta x)^2 + 3x^2 \left(1 - \frac{dx}{\Delta x} \right)
Can I say that \lim_{\Delta x \to 0} \Delta x = dx so that
\lim_{\Delta x \to 0} \varepsilon = 3x(0) + (0)^2 + 3x^2(1-1) = 0 ?
GunnaSix said:
Let V=x^3
\Delta V - dV
dV = 3x^2 dx
I worked it down to
You basically have it. You need to note that \Delta x and dx are the same thing, regardless of limits. Using your equations:
<br /> dV = 3x^2 dx [= 3x^2\Delta x]<br /> <br />
<br /> \Delta V = 3x^2 \Delta x + 3x (\Delta x)^2 + (\Delta x)^3<br />
you have:
<br /> \Delta V-dV= 3x (\Delta x)^2 + (\Delta x)^3 = (\Delta x)(3x\Delta x + (\Delta x)^2))= \Delta x (\varepsilon)<br />
Does this \varepsilon work? Note that you don't need to take any limits to answer the question. You just need to observe that \varepsilon \rightarrow 0 as \Delta x does.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
