LucasCampos
- 17
I've made a program that uses more than 72 characters per line. When I try to compile it on gfortran, using -ffixed-line-length-n, it returns several errors, all of them derived from a line truncated at the very beggining. How can I compile it or untruncate the line?
The code is as follows
Code:
Program Rotation
Implicit None
Double Precision dt,ve,mass,radius,height,pmass,vx,vy,area,rad,de,weight,g,t,tmax,ymax,rangmax,inertia,pweight,tet,ar,torque,vymid,vxmid,dy,dx,ax,ay,rang,w
Integer nshow,counter
CALL Opener
CALL Inserter (dt,ve,de,tet,w,mass,radius,height,pmass,nshow)
CALL Calc (ve,vx,vy,mass,radius,area,rad,de,weight,g,t,tmax,ymax,rangmax,inertia,pmass,pweight,counter)
CALL Torq (pweight,tet,ar,inertia,torque)
CALL Velocitymed (vx,vy,ay,ax,t,dt,vymid,vxmid)
CALL Drags (vx,vy,vymid,vxmid,dy,dx,area,ax,ay,weight,mass)
CALL Euler (radius,mass,area,weight,vxmid,vymid,vy,vx,dy,dx,ay,ax,t,dt,height,rang,rangmax,tmax,ymax,ar,w,tet,inertia,torque,pweight,counter,nshow)
CALL print_table (vx,vy,t,ax,ay,dx,dy,height,rang,tet,w,ar)
End
Subroutine inserter (dt,ve,de,tet,w,mass,radius,height,pmass,nshow)
Implicit None
Double Precision dt,ve,de,tet,w,mass,radius,height,pmass
Integer nshow
Write (*,*) 'Insert time step(s)'
Read (*,*) dt
Write (*,*) 'Insert initial height(m)'
Read (*,*) height
Write (*,*) 'Insert initial translational speed (m/s)'
Read (*,*)ve
Write (*,*) "Insert inital translational speed's angle to the ground (degrees)"
Read (*,*)de
Write (*,*) 'Insert initial angular space (rad)'
Read (*,*) tet
Write (*,*) 'Insert initial angular speed (rad/s)'
Read (*,*) w
Write (*,*) "Insert disk's mass(kg)"
Read (*,*)mass
Write (*,*) "Insert point's mass(kg)"
Read(*,*) pmass
Write (*,*) 'Insert radius(m)'
Read (*,*)radius
Write (*,*) 'Insert number os steps between output'
Read (*,*)nshow
End
Subroutine Calc (ve,vx,vy,mass,radius,area,rad,de,weight,g,t,tmax,ymax,rangmax,inertia,pmass,pweight,counter)
Implicit None
Double Precision ve,vx,vy,mass,radius,area,rad,de,weight,g,t,tmax,ymax,rangmax,inertia,pmass,pweight
Integer counter
g=-9.8
t=0.0D0
rad=de*0.0174532925
vx=ve*(cos(rad))
vy=ve*(sin(rad))
area=3.141592654*(radius**2)
weight=mass*g
pweight=pmass*g
counter = 0
ymax = -5000
tmax = -5000
rangmax = -5000
inertia=(pmass+mass)*(radius**2)*0.66
END
Subroutine Torq (pweight,tet,ar,inertia,torque)
Implicit None
Double Precision pweight,tet,ar,inertia,torque
torque=pweight*cos(tet)
ar=torque/inertia
End
Subroutine Velocitymed (vx,vy,ay,ax,t,dt,vymid,vxmid)
Implicit None
Double Precision vx,vy,ay,ax,t,dt,vymid,vxmid
IF (t .EQ. 0.0D0) vymid = vy
IF (t .EQ. 0.0D0) vxmid = vx
IF (t .NE. 0.0D0) vymid = vy+(ay*(dt/2))
IF (t .NE. 0.0D0) vxmid = vx+(ax*(dt/2))
END
Subroutine Drags (vx,vy,vymid,vxmid,dy,dx,area,ax,ay,weight,mass)
Implicit None
Double Precision vx,vy,vymid,vxmid,dy,dx,area,ax,ay,weight,mass
IF (vy .LT. 0.0D0) dy=(vymid**2)*area*0.5D0
IF (vy .GT. 0.0D0) dy=-(vymid**2)*area*0.5D0
IF (vx .LT. 0.0D0) dx=(vxmid**2)*area*0.5D0
IF (vx .GT. 0.0D0) dx=-(vxmid**2)*area*0.5D0
ay=(dy+weight)/mass
ax=dx/mass
END
Subroutine Euler (radius,mass,area,weight,vxmid,vymid,vy,vx,dy,dx,ay,ax,t,dt,height,rang,rangmax,tmax,ymax,ar,w,tet,inertia,torque,pweight,counter,nshow)
Implicit None
Double Precision radius,mass,area,weight,vxmid,vymid,vy,vx,dy,dx,ay,ax,t,dt,height,rang,rangmax,tmax,ymax,ar,w,tet,inertia,torque,pweight
Integer counter,nshow
100 IF (mod(counter,nshow) .EQ. 0) Call print_table (vx,vy,t,ax,ay,dx,dy,height,rang,tet,w,ar,radius)
Call Euler_Disk (mass,area,weight,vxmid,vymid,vy,vx,dy,dx,ay,ax,t,dt,height,rang,counter,nshow)
Call Euler_pointr (ar,w,tet,dt,inertia,torque,pweight)
counter = counter + 1
IF (height .GT. ymax) tmax=t
IF (height .GT. ymax) rangmax=rang
IF (height .GT. ymax) ymax=height
IF (height .LT. 0.0D0) Go to 200
t=t+dt
Go to 100
200 WRITE(11,*) tmax,ymax
End
Subroutine Euler_pointr (ar,w,tet,dt,inertia,torque,pweight)
Implicit None
Double Precision ar,w,tet,dt,inertia,torque,pweight
Call Torq (pweight,tet,ar,inertia,torque)
w=w+(ar*dt)
tet=tet+(w*dt)
End
Subroutine Euler_Disk (mass,area,weight,vxmid,vymid,vy,vx,dy,dx,ay,ax,t,dt,height,rang,rangmax,tmax,ymax,counter,nshow)
Double Precision mass,area,weight,vxmid,vymid,vy,vx,dy,dx,ay,ax,t,dt,height,rang,rangmax,tmax,ymax
vy=vy+(ay*dt)
vx=vx+(ax*dt)
height=height+(vymid*dt)
rang=rang+(vxmid*dt)
End
Subroutine print_table (vx,vy,t,ax,ay,dx,dy,height,rang,tet,w,ar,radius)
Implicit None
Double Precision vx,vy,t,ax,ay,dx,dy,height,rang,tet,w,ar,radius
WRITE (1,*) t,vx
WRITE (2,*) t,vy
WRITE (3,*) t,ax
WRITE (4,*) t,ay
WRITE (12,*) t,dx
WRITE (13,*) t,dy
WRITE (14,*) t,height
WRITE (15,*) rang,height
WRITE (16,*) t,rang
WRITE (17,*) t,tet
WRITE (18,*) t,w
WRITE (19,*) t,ar
Write (20,*) t, (height+(radius*sin(tet)))
Write (21,*) (rang+(radius*cos(tet))), (height+(radius*sin(tet)))
Write (22,*) t, (rang+(radius*cos(tet)))
END
Subroutine Opener
OPEN (Unit=1,FILE="vx.dat")
OPEN (Unit=2,FILE="vy.dat")
OPEN (Unit=3,FILE="ax.dat")
OPEN (Unit=4,FILE="ay.dat")
OPEN (Unit=11,FILE="heightmax.dat")
OPEN (Unit=12,FILE="dragx.dat")
OPEN (Unit=13,FILE="dragy.dat")
OPEN (Unit=14,FILE="height.dat")
OPEN (Unit=15,FILE="rangeheight.dat")
OPEN (Unit=16,FILE="range.dat")
OPEN (Unit=17,FILE="angle.dat")
OPEN (Unit=18,FILE="rspeed.dat")
OPEN (Unit=19,FILE="rotacce.dat")
OPEN (Unit=20,FILE="point's height.dat")
OPEN (Unit=21,FILE="Full.dat")
OPEN (Unit=22,File="point's range.dat")
END
