Linear Actuator -- Why is this not working?
4 replies · 2K views · last reply
trickyrick0465
I'm using the actuator that says its good for 270lb
https://www.princessauto.com/en/detail/12v-dc-12-in-stroke-270-lb-linear-actuator/A-p8507840e
I'm using the 4rth pully system from here
Pulley diagram
I'm using it to lift 40 lbs
So from the diagram I figured that to lift 40 lbs I need an actuator to handle 160 lbs 4 times what I want to really lift
I'm finding that it struggles to even lift 40 lbs
What am I missing
Pulley diagram
What am I missing
Welcome to PhysicsForums.
What are you using for the 12Vdc 5Amp power source? Could it be drooping?
berkeman
Thanks for pointing me in the right direction. The actuator couldn't draw enough current. Switched to a 12V deep cycle battery and works now. I've never used an Actuator when it lifts the weight it sounds like its under a lot of stress.
Thanks guys
Depending on your system, there can be a lot of friction in that pulley system. This does not seem to be taken into account in your work.
