Linear Algebra - set of piecewise continuous functions is a vector space
The discussion centers on proving that the set of piecewise continuous functions on the interval [a, b] forms a vector space over ℝ. It is established that if two piecewise continuous functions are added, their sum remains piecewise continuous, satisfying the continuity conditions at points where both functions are continuous. Additionally, scalar multiplication of a piecewise continuous function also results in a piecewise continuous function, ensuring closure under this operation. The discussion confirms that the additive identity is the zero function, which is continuous, and the additive inverse of any function is also piecewise continuous. Overall, the properties required for a vector space are satisfied, confirming that the set of piecewise continuous functions is indeed a vector space.
corey115
A function f:[a,b] \rightarrow ℝ is called piecewise continuous if there exists a finite number of points a = x0 < x1 < x2 < ... < xk-1 < xk = b such that
(a) f is continuous on (xi-1, xi) for i = 0, 1, 2, ..., k
(b) the one sided limits exist as finite numbers
Let V be the set of all piecewise continuous functions on [a, b]. Prove that V is a vector space over ℝ, with addition and scalar multiplication defined as usual for functions.
The axioms for fields and vector spaces.
If function addition and scalar multiplication work in the same way as usual, don't I just have to make an argument that the limits still exist as finite numbers (since our scalars are finite)? And a similar argument that if I add two functions that those limits will just be the sum of the two limits of each function?
Suppose f, g\in V, and let h = f + g. If f and g are both continuous at a point x, what can you say about h at that point? Is it continuous at x?
It will also be continuous because the sum of two continuous functions will also be continuous. But do I need extra arguments besides that because V is the set of piecewise continuous functions?
Yes, but we have learned something already. h will be continuous at any point where both f and g are continuous, so h can only be discontinuous at points where f or g are discontinuous, and there are only finitely many such points. Thus h can have only finitely many discontinuities. So h satisfies condition (a).
Now consider condition (b). If h is discontinuous at x, what are \lim_{y \rightarrow x^+} h(x) and \lim_{y \rightarrow x^-} h(x)? Can you write these in terms of the corresponding one-sided limits of f and g?
Would that not be just the sum of the two limits of f and g at x, or if one or both of those two functions is discontinuous at x, then I would just use the whatever sided-limit that I need?
Right, you have \lim_{y \rightarrow x^+} h(y) = \lim_{y \rightarrow x^+} f(y) + \lim_{y \rightarrow x^+} g(y), and similarly with the left hand limit. Since these limits exist for f and g, they also exist for h. This shows that h satisfies (b).
So that shows that V is closed under addition. What else do you need to show in order to prove that V is a vector space?
Closure under scalar multiplication.
Commutative/Associative for addition/multiplication.
Additive identity/inverse.
Multiplicative identity.
Distributive property.
Associative property for scalar multiplication.
OK, these three are true for any functions so they remain true for piecewise continuous functions.
Which functions do these correspond to? Are they piecewise continuous?
If f \in V and c is a scalar, is cf piecewise continuous? Should be pretty easy to show that it is.
For the 2nd item you listed, would the additive inverse of f be -f and the additive identity of f be the 0 function that is discontinuous where ever f is discontinuous?
As for the 3rd item, I'm not entirely sure how I would go about showing that. It makes sense intuitively as to why it would be true, but I'm not sure how to put that on paper.
Yes. Note that -f is discontinuous at exactly the same points as f, and the left and right limits exist because they exist for f. (Insert easy proofs as needed.)
The additive identity of V would be just the standard 0 function, which is continuous everywhere. Note that all continuous functions are in V because the number of discontinuities (zero) is certainly finite, and the left and right limits exist due to continuity.
Claim: cf is continuous at any point x where f is continuous. (Proof?) Therefore cf has at most finitely many discontinuities. What about \lim_{y \rightarrow x^+} cf(y)? What does this equal?
Since that is just a constant (scalar in our case), it would equal c times whatever the limit of just f(x) was.
Right. Expressing it formally:
$$\lim_{y \rightarrow x^+} cf(y) = c \lim_{y \rightarrow x^+}f(y)$$
by the linearity property of limits, and the right hand side exists because f \in V.
You have been more than helpful! I feel like I have a much greater understanding of this proof now!
  • · Replies 17 ·
  • · Replies 18 ·
