Linear algebra, vector spaces (for quantum)
The discussion centers on understanding whether a collection of polynomials of degree less than N constitutes a vector space and the implications of various constraints on these polynomials. It is established that the set of all such polynomials does form a vector space with a basis of {1, x, x^2, ..., x^(N-1)}, giving it a dimension of N. When polynomials are restricted to even functions, the dimension is reduced to N/2 if N is even, or (N-1)/2 if N is odd, as only even powers are included. For polynomials with a leading coefficient of 1, the space is not a vector space since it is not closed under addition. The conversation highlights the importance of linear independence and the definition of vector spaces in determining the dimensions and bases of these polynomial sets.
saraaaahhhhhh
I have never taken linear algebra, but we're doing some catch-up on it in my Quantum Mechanics class. Using teh Griffiths book, problem A.2 if you're curious.
Please explain how to solve this, if you help me. If you know of resources on how to think about this stuff, I'd greatly appreciate the assistance.
Consider the collection of all polynomials (with complex coefficients) of degree less than N in x.
a.) Does this set constitutte a vector space (with the polynomials as vectors)? If so, suggest a convenient basis and give the dimension of the space. If not, which of the defining properties does it lack?
b.) What if we require that the polynomials be even functions?
c.) What if we require that the leading coefficient (i.e., the number multiplying x^(N-1)) be 1?
d.) What if we require that the polynomials have the value 0 at x=1?
e.) What if we require that the polynomials have the value 1 at x=0?
My attempt at a solution is:
a.) Yes, it doesw consitute a vector space. Any vector would be an ordered N-tuple (?) constructed from teh coefficients. How would I answer about the dimension of the space? Does it have N dimensions? I'm not sure if I understand what is being asked.
b.) Nothing changes?
c.) Then you'd have a pretty boring vector space? But I think all the rules would work.
d.) Still a vector space?
e.) Still a vector space? I don't see why that would change, I must be missing something.
I don't know where to start. If Griffith doesn't have the introductory material then start with the usual on-line reference. http://en.wikipedia.org/wiki/Vector_space The key point is that vector spaces are more then just n-tuples of numbers. They are sets of objects that combine 'like' n-tuples of numbers. To start with the first one, all of your polynomials look like p(x)=c0+c1*x+c2*x^2+...+cn*x^(N-1), right? Can you suggest a set of simple functions of x that you can combine with constant coefficients that are linearly independent (study that concept) with which you can make any polynomial of degree less than N? Yes, the dimension is N. For the second one, something does change. p(x) is even means p(x)=p(-x). Not all polynomials satisfy that. The dimension is lower. How much lower? Like I said, this is a big subject. Post these questions one at a time and you'll probably get more help.
Thanks for the tip.
I must be confused from what my teacher's notes are saying. He basically said the vectors would be defined as polynomials, like your p(x) above.
And this sentence:
"Can you suggest a set of simple functions of x that you can combine with constant coefficients that are linearly independent (study that concept) with which you can make any polynomial of degree less than N?"
is nearly meaningless to me. I understand linear independence, but why would I use simple functions of x to make a polynomial?
What do you mean that vector spaces are sets of objects that combine "like" n-tuples of numbers? A vector space is a set of vectors, right? Vector objects.
Okay, so b.) has N/2 dimensions, then.
You do use simple functions to make polynomials. You combine {1,x,x^2,...x^(N-1)} to make a general polynomial. And if you understand linear independence, great! They are linearly independent. So they are a basis for all polynomials. And they span a space that is a lot like the space of n-tuples. But they aren't "n-tuples", they are functions. Sort of right for b). If you have polynomials of degree less than 3, is the dimension 3/2?
I see your point, but I don't know how to generalize the value for the dimension.
From what you're saying: in part a.), the basis is simply the set of {1, x, x^2...x^(N-1)} and teh vectors are represented by the coefficients {c_0, c_1...c_(N-1)}. Okay, that makes sense.
For part b.), the dimension is not N/2 but something like it...N/2 if N is even, and N-1/2 if N is odd? There may be a better way to say that. And the basis is now the set {1, x^2, x^4...x^(N...?)}, or something close? With coefficients {c_o, c_2, c_4...etc}? This would happen because only the even-exponent values in teh polynomial are even functions.
For part c.), wouldn't the vectors span the space, because they are linearly dependent, because they are all just {1, 1, 1,...}? Then would the basis be 0? Would the dimension be 1?
For part d/e I am still at a loss.
Saying N/2 for N even and (N-1)/2 for n odd is just fine. For part c), review the definition of a vector space. If O is the set of polynominals with the coefficient of x^(N-1) equal to 1, is it closed under addition? If you add to elements of O, do you get an element of O?
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 24 ·
