Linear diff eq - correctly done?
  • Thread starter Thread starter Asphyxiated
    Diff eq Linear
Asphyxiated
Solve the linear differential equation:
xy'-2y=x^{2}
If you have a linear differential equation of the form:
y'+P(x)y=Q(x)
then your integrating factor is:
I(x)=e^{\int P(x) dx}
If we divide both sides by x then the equation is in standard form:
y' - \frac {2y}{x} = x
where
P(x)=-\frac{2}{x}
thus:
I(x)=e^{\int -\frac{2}{x} dx} = e^{-2\int\frac{1}{x}dx}= e^{-2ln|x|}=x^{-2}
so we then multiple both sides of the diff eq by I(x):
x^{-2}y'-2x^{-3}y=\frac{1}{x}
which is:
\frac {d}{dx}(x^{-2}y)=\frac{1}{x}
if we the integrate both sides:
x^{-2}y=ln|x|+c
therefore:
y= x^{2}ln|x|+cx^{2}
Looks good to me.
Your solution is easy enough to check. Substitute your solution for y and take its derivative. When you evaluate xy' - 2y, you should get x2.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
