What is the Angular Momentum of a Projectile at a Given Time?
In summary, a restored Civil War cannon is being tested using cannonballs of various mass and using various loads of gunpowder. The cannon fires a cannonball at a speed of 107 m/s in a direction which is 48 degrees Up from East. The near edge of the mesa is a vertical cliff which is 153 meters high; the base of the cliff is 186 meters to the east of the cannon.
mathwhiz
Background
The concepts of torque and angular momentum are unnecessary when analyzing the motion of a projectile; however, using these concepts for an analysis of projectile motion does show that the concepts are perfectly general, and are not restricted purely to the analysis of rotation. You should regard this problem as chiefly a mathematical exercise in using the cross product definitions of torque and angular momentum.
A restored Civil War cannon is being tested using cannonballs of various mass and using various loads of gunpowder. In one test, the cannon fires a cannonball at a speed of 107 m/s in a direction which is 48 degrees Up from East. The cannonball is intended to land on a mesa which is to the east of the cannon. The near edge of the mesa is a vertical cliff which is 153 meters high; the base of the cliff is 186 meters to the east of the cannon.
In answering the questions below, use an xy coordinate system with East as the positive x direction and Up as the positive y direction.
Specifically
(g) Use the definition of angular momentum, in three dimensions, along with your equations for the position of the cannonball (as measured from the base of the cliff) and the velocity of the cannonball, to find an equation for the angular momentum of the cannonball as a function of time, as measured with respect to the point at the base of the cliff. Use that equation to determine the angular momentum of the cannonball at the following times. Because your position and velocity vectors are all in the xy plane, your angular momentum vectors will always be purely in the positive or negative z directions. Take South as the positive z direction, and indicate the direction of angular momentum by the appropriate algebraic sign. Mass of cannonball 5.5kg
Determine the z component of angular momentum for the following times:
At t = 2.0 s, Lz = ________ kg * m2/s
Answers to previous questions
At t = 2.0 s, x = 143.19 m and y = 139.43 m
At t = 4.0 s, x = 286.39 m and y = 239.67 m
At t = 6.0 s, x = 429.58 m and y = 300.7 m
At t = 2.0 s, vy = 59.92 m/s.
At t = 4.0 s, vy = 40.32 m/s.
At t = 6.0 s, vy = 20.72 m/s.
When passing over the cliff edge, vy = 54.14 m/s.
Just before crashing into the ground, vy = -57.88 m/s.
X position w.r.t the base of cliff
At t = 2.0 s, xC =-42.81 m
At t = 4.0 s, xC = 100.39 m
At t = 6.0 s, xC =243.58 m
Just before crashing into the ground, xC = 817.79 m
L = r x p
L = rmvsinθ
My attempt was to use pythagoras to find r vector from base of cliff to the cannonball at t = 2 s
sqrt(139.432+(-42.81)2) = 145.85m
Then I needed an angle between the position and and origin so at t = 2s
arcttan(139.43/42.81) = 72.93°
I also need a velocity so I used pythagoras once again to get actual velocity at t = 2 s
sqrt(Vx2+Vy2)
=sqrt(71.5972+59.922)
=93.36 m/s
then plug everything into equation r X p
L = 145.85m(5.5kg)(93.36m/s)sin(72.93°0
= 71596.533 kg*m2/s
The vector should be negative by RHR.
I believe I may be looking at the wrong angle, any kind of guidance would be appreciated.
That is just too difficult and error-prone. Dealing with angles in such a way is always messy. Use vectors throughout, it is much simpler. You know that the x-component of the velocity vector is some constant ## v_x ##; the y-component is ## v_y - gt ##; the x-component of the displacement vector is ## v_x t ## and its y-component is ## v_y t - \frac {gt^2} 2 ##. The angular momentum is ## \vec r \times \vec p ##, using the properties of the cross product, its z-component is ## m (v_x t (v_y - gt) - (v_y t - \frac {gt^2} 2) v_x) = - m \frac {g t^2} 2 v_x ##, so all you really need to do is find ## v_x ##, the x-component of the initial velocity.
Sorry for the delay, so I understand what your saying about using just vectors. The answer I got using the equation was -7718.15 kg*m2/s. Webassign said it was wrong, but I'm going to go back and use stored values since it is real sensitive about sig figs.
No, wait. I missed that the problem said the origin of the coordinate system must be at the base of the cliff, and placed it at the cannon. That changes the displacement components by adding some fixed offsets. I will let you do the algebra this time.
Okay so I used (RXP)z=rxpy-rypx
I ended up with
(Vi,xt)[(Vi,y-gt)m]-(Vit+.5at2)(Vxm) = mt[Vi,xVi,y-Vi,xgt-Vi,yVx+(Vxat)/2]
All of the Vx's and Vi's started jumbling together towards the end so I may have done the algebra wrong hence why I got the wrong answer, I'm going to redo it right now
Here is another trick. Let's say that the initial position of the ball is ## \vec r_0 ##. Then at any time ## \vec r = \vec r_0 + \vec r' ##, where ## \vec r' ## is the displacement from the cannon. Now, angular momentum is ## \vec r \times \vec p = \vec r_0 \times \vec p + \vec r' \times \vec p ##. We have already found that the z-component of ## \vec r' \times \vec p ## is ## -m \frac {gt^2} 2 v_x ##; the z-component of ## \vec r_0 \times \vec p ## is ## m(r_x(v_y - gt) - r_y v_x) ##, where ## r_x ## and ## r_y ## are components of ## \vec r_0 ##; so the full z-component is $$ m \left[ r_x(v_y - gt) - \left( r_y + \frac {gt^2} 2 \right) v_x \right]$$ Far messier than before, but still manageble with a calculator.
Likes 1 person
I appreciate all of the help, I only have a certain amount of tries and I have almost exhausted all of them for this part. I am going to talk with my professor tomorrow at this point, I will post the solution tomorrow after speaking with him or the TA's at the school. Thanks again
So, we were on the right track with using properties of cross products but it should have been like this.
L = r X p
= (xi+yj) X m(Vxi + Vyj)
after simplifying we get,
L = m[xVyk + yVx(-k)]
x being distance from origin @ specific time, and y being height @ specific time.
He did say I was making it to complicated with how I was trying to do it at first.
What is linear momentum of a projectile?
Linear momentum of a projectile is defined as the product of its mass and velocity. It is a vector quantity and is represented by the symbol p. In simpler terms, it is the measure of the amount of motion possessed by a projectile in a specific direction.
How is linear momentum of a projectile calculated?
The linear momentum of a projectile can be calculated by multiplying its mass (m) by its velocity (v). The formula for linear momentum is p = m * v. The SI unit of linear momentum is kg * m/s.
What factors affect the linear momentum of a projectile?
The linear momentum of a projectile can be affected by its mass, velocity, and direction of motion. An increase in mass or velocity will result in an increase in linear momentum, while a change in direction will alter the direction of the momentum vector.
How does air resistance affect the linear momentum of a projectile?
Air resistance can reduce the linear momentum of a projectile by decreasing its velocity. This is because air resistance acts in the opposite direction of the projectile's motion and causes a decrease in its speed. However, if the projectile has a large enough initial velocity, it can overcome air resistance and maintain its momentum.
What is the principle of conservation of linear momentum?
The principle of conservation of linear momentum states that in a closed system, the total linear momentum of all objects remains constant. This means that in the absence of external forces, the initial linear momentum of a system will be equal to the final linear momentum. This principle is often used to analyze collisions between projectiles and other objects.
