Why Does Concrete Contract Differently in Cold Temperatures?
The contraction of a concrete slab measuring 18 meters in length when the temperature drops from 24 °C to -16 °C is calculated using the coefficient of linear thermal expansion for concrete, which is 10^-5 per degree Celsius. The correct formula is: change in length = a * Lo * change in temp, where Lo is 1800 cm and the temperature change is -40 °C. The calculation yields a contraction of approximately 0.72 cm, which may be rounded to 0.5 cm in some contexts. Errors in initial calculations were likely due to incorrect temperature change interpretation and unit conversions.
  • Understanding of linear thermal expansion concepts
  • Familiarity with the formula for calculating changes in length due to temperature
  • Basic knowledge of unit conversions, particularly between degrees Celsius and centimeters
  • Ability to perform calculations involving coefficients of thermal expansion
  • Review the principles of thermal expansion in materials science
  • Study the effects of temperature on concrete properties
  • Learn about unit conversion techniques in physics
  • Explore common rounding practices in scientific calculations
Students in physics or engineering fields, construction professionals, and anyone interested in material properties and thermal effects on concrete structures.
titusdna
Got this question wrong on this weeks physics quiz and can't figure out why. I keep getting the same answer - which was wrong - over and over. What am I missing?
By how much will a slab of concrete 18 m long contract when the temperature drops from 24 °C to -16 °C? (The coefficient of linear thermal expansion for concrete is 10-5 per degree C.)
Answers are in centimeters.
Formula:
change in length= a* Lo* change in temp
Lo = 1800cm
A = 10-5
change in T = 24- (-16) = 40
I keep coming up with .7 cm
the answer was .5cm
Where did I go wrong? Any help greatly appreciated
Thank you
I can't find an error in your calculations. Maybe the result was rounded in the answers or there's a typo somewhere?
for reaching out for help with this question. It seems like you have the correct formula and values, so let's go through the steps to see where the error may have occurred.
First, let's check the units. The coefficient of linear thermal expansion is given in 10^-5 per degree C, so we need to make sure that our temperature change is also in degrees Celsius. In this case, 24 °C to -16 °C would be a change of -40 °C, not 40 °C.
Next, let's double check the calculation. Using the formula, we get:
change in length = (10^-5) * 1800cm * (-40 °C) = -0.72 cm
So it looks like the answer should be -0.72 cm, which is close to the answer you were getting. However, the question asks for the change in length in centimeters, so we need to take the absolute value of this answer. This gives us a final answer of 0.72 cm, which is closer to the given answer of 0.5 cm.
It's possible that there was a rounding error at some point in the calculations, or an incorrect unit conversion. Make sure to always double check your units and calculations to avoid any errors. I hope this helps and good luck on your future quizzes!
21K
