LM324 squarewave oscillator adjust output frequency
5 replies · 10K views · last reply
nheugel
I have designed an opamp based on thfollowing square wave setup http://www.national.com/ds/LM/LM124.pdf on page 11. I want to know what i would have to adjust to lower the frequency to the range of 10 hertz, it has a 5 volt input and the frequency range is at 10 Ghz I believe. any help would be appreciated.
If you mean the example square wave oscillator on page 11 of that datasheet, it most certainly does not operate in the GHz range of frequencies. The frequency will be around the RC time constant of the feedback shown. You may be able to get down to 10Hz with large enough values of R and C, or you could use a counter to divide down to 10Hz from a higher oscillator frequency. You could use a CD4020, CD4040, or CD4060, for example.
The R1 feedback resistor in the schematic on page 11 probably should not exceed about 200K, because the input bias current is <= 200nA.
can oscillation be created without the the lm ic s if yes why and how bob s
Build a relaxation oscillator using a Ne2 neon bulb. See
http://www.cliftonlaboratories.com/relaxation_oscillator.htm
Bob S
If you just want to avoid the use of an integrated circuit, the following circuit uses only 4 components and a 1.5 volt battery.
It makes a surprising level of output from a speaker and is handy as a doorbell or unattended desk alert.
Battery current is very low due to the speaker output being in the form of short pulses.
[PLAIN]http://dl.dropbox.com/u/4222062/NPN%20PNP%20OSC.PNG
