When to Use Ln vs Log in Calculating Derivatives?
  • Thread starter Thread starter Drake M
    Ln Log
The discussion clarifies the distinction between using "log" and "ln" in calculus, particularly in derivatives. It highlights that "ln(u)" typically denotes the natural logarithm (base e), while "log(u)" can refer to base 10 or natural logarithm depending on the context, leading to potential confusion. The derivative of "ln(u)" is confirmed as 1/u, while using "log(u)" requires careful consideration of the base. The conversation also notes that conventions vary across textbooks and computer algebra systems, with a recommendation to specify the base when using "log" to avoid ambiguity. Overall, understanding these notations is crucial for accurate calculations in calculus.
Drake M
I'm having a hard time differentiating when to use log instead of ln, vice versa. Are there any general rules to follow?
For example I have to evaluate 4u^-3 + u^-1.
f'(1/u) = log u
f'(1/u) = ln u
I put -2u^-2 + log(u) but the textbook solution shows the same answer except with ln.
The derivative of 1/u is ln(u), not log10(u). When you are dealing with derivatives or integrals, the natural log has an advantage. In those situations, log10 requires that you correctly include factors of ln(10) in your answers.
CORRECTION: The derivative of ln(u) is 1/u. ( Thanks @lcgldr)
f'(1/u) = log u
f'(1/u) = ln u
Some books and papers denote the natural logarithm of ##u## as ##\log(u)## instead of ##\ln(u)##. Some other books reserve the notation ##\log(u)## for log to base 10 of ##u##. Still others use ##\log_{10}(u)## instead in that context.
I do believe that the most common forms are ##\ln(u)## for ##\log_e(u)## and ##\log(u)## for ##\log_{10}(u)##, but I have no statistics on that issue.
Some computer algebra systems adopt similar standards. For example, Maple accepts either "log(u)" or "ln(u)" for ##\ln(u)## but prints it out as ##\ln(u)##. It needs the fancier notation "log[a](u)" for ##\log_a(u)## when ##a \neq e##. I don't have access to Mathematica, so I don't know what conventions it adopts.
Just for clarity, I recommend the use of ln() for base e and loga() for arbitrary base a. Otherwise, it leaves people guessing what base you want. It's nicer to specify the base when you use 'log'.
The exception is in math books like complex analysis, where the base is always e, regardless of the 'ln', versus 'log' choice.
Likes PeroK
I think the notation ##\ln u## is common in applied, less rigorous mathematics, especially senior high school level math. Pure mathematics literature usually assumes that ##\log u## means the base ##e## logarithm unless otherwise stated. The base-10 logarithm is important in chemistry, where the pH scale is defined with it.
Likes vela and FactChecker
I meant to thank you all for your help sooner but i got caught up in test and mid-terms. Thanks!
