Load and deflection (beam experiment)
The relationship between load and deflection in beam experiments is directly proportional, meaning changes in load will affect deflection correspondingly. However, the relationship between deflection and span is not linear; deflection typically increases with the span raised to the third power. As the span increases, the bending moment also increases, influenced by the distance between forces and their direction. The discussion emphasizes the need for a deeper understanding of these relationships in structural analysis. Overall, clarifying these concepts is crucial for accurately predicting beam behavior under load.
student 123
hi, iv just got a few questions and I am hoping someone can help me:)
1) so the relationship between load and deflection is liner but how can i explain it further?
2) and I am not sure about the relationship between deflection and span?
3) and what happens to bending moment as the span is increased?
i know all of them can be defined in one sentence of two but i will be greaful if someone can explain this to me in detail,
my attempt not sure if its correct:
The load and deflection are directly proportional to each other which tells us if either load is changed it will have a direct effect on deflection and vice versa.
When calculating the bending moment distance between forces and direction are taken into account, as the span is increased the bending moment also increases.
Like load and deflection span and deflection also share a liner relationship
Much of this assessment is correct. But the load deflection is definitely not a linear function of the span. Typically, the deflation with be proportional to the span to the 3rd power.
