Load bearing capacity of a friction hinge?
The discussion focuses on calculating the load bearing capacity of a friction hinge used for a door weighing 4.5 lbs, with dimensions of 7" width and 19" length. The hinge, measuring 3.2" in length with a pin diameter of .230 inches and leaf thickness of .06", is mounted at the center of the door. While the consensus suggests that using two hinges would provide better strength, the specific application constraints allow for only a single hinge due to limited space. The door will remain closed most of the time, only opening for service twice a year.
  • Understanding of load calculations in mechanical systems
  • Familiarity with friction hinge mechanics
  • Knowledge of material strength and stress distribution
  • Basic principles of door hardware installation
  • Research methods for calculating load bearing capacity of hinges
  • Explore alternative hinge designs for limited space applications
  • Learn about stress analysis in mechanical components
  • Investigate best practices for door installation with single hinges
Mechanical engineers, hardware designers, and anyone involved in door installation and load management in constrained spaces.
RCAN
The door is 4.5 lbs evenly distributed. Width is 7" and length is 19". The door is mounted by using a friction hinge at the center . How to calculate the total load acting on the hinge? What is the maximum load bearing capacity of the hinge? Length of hinge is 3.2" and diameter of pin is .230 inches, leaf thickness is .06".
That is not the best arrangement for a hinge if you are worried about strength . Ideally you should have two hinges - one at the top of the door and one at the bottom .
Agree with your point regarding two hinges. Here in my application space is limited to provide hinges at top and bottom. The door will be in closed condition always and open only for service (max two times a year)
