Load distribution of rotating body
The discussion focuses on load distribution for a rotating platform designed to support optical and thermal components. The optical components weigh 1 ton and cover an 8 m x 8 m area, while the thermal components weigh 1.5 tons and occupy a 1 m x 1 m area. To achieve balanced load distribution across the wheels, dummy loads should be strategically placed, considering the center of gravity of the equipment. The placement of these loads should minimize the moment about the platform's center, ensuring equal weight on each wheel. Additionally, adjusting wheel placement may help further equalize the load distribution.
Mr Zakaria
Hi everyone,
I'm working on load distribution of what to be put on a platform.
The platform will be rotated by the wheels placed at the circumference of the platform.
The loads that need to be put are the optical components which have mass of 1 ton which will cover 8 m x 8 m area and thermal components with mass of 1.5 tons which will have an area of 1 m x 1 m area. The platform has an area of 10 m x 10 m. For load balancing, i think dummy load should be placed to make sure load distribution on the wheels is balanced. Does anyone know how is the right way to go about to place the dummy load?
Thank you in advance
It depends on whether you want equal weight on each wheel, or an inertially balanced platform when it is rotated very fast.
We want to have equal weight on each wheel. The platform will be rotating very slowly following the sun.
If there is an 'optical center' that needs to be at or near the center of rotation, that will effect the possible distribution, possibly making it impossible to balance the loading.
Can the dummy weights be incorporated within the foot print of the optical equipment?
To balance the loading, first place the optical and thermal equipments, cg's on a diameter, then move these along that diameter to minimize the moment about the center of the platform, and of course keeping them on the platform. Once you have them placed to minimize the moment, then add the dummy weights to get a zero moment at the center of the platform. The dummy weights will need to be placed equal distances off the diameter.
You may also want to consider arranging and/or adding wheels at various places around the platform to equalize the loading on the wheels. The wheels do not have to be arranged symmetrically around the platform.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
