Load line of transistor question
9 replies · 4K views
Outrageous
In order to draw the load line of transistor, we have to find out the saturation current (where the voltage is minimum or zero) and voltage of collector-base when collector current is zero.
In order to calculate maximum saturation current, we have to forward biased the base-emitter, and reverse biased the base -collector and then get the voltage of collector-emitter to be zero(V of collector minus voltage of emitter equals to zero), right??
Thank you
I think 'we have to forward biased the base-emitter, and reverse biased the base' instead of both forward because when we forward both we can't get a constant curve at saturation region, correct?
the base-emitter junction is always forward biased as long as the transistor is not in full "cut-off" (where the collector current is zero). so, from the POV of the load line, the base-emitter is forward biased, usually by about 0.6 volts.
what is POV?
The base-emitter is usually 0.7V.
How to draw a load line?
Outrageous said:
what is POV?
POV = "point of view"
First of all there is not one load line for a transistor.
There are many and they depend upon the circuit configuration.
Having said that, for a resistive load the load line is a straight line so you only need to find two points and join them to be able to draw one.
To draw a load line for R ohms on the collector current (y axis) v collector voltage (x axis) curves:
1)Locate the point of the voltage axis corresponding to the supply voltage.
2)Locate the point on the current axis which the supply voltage would drive through R ohms.
3) Join these two points to form the load line for R ohms.
go well
Thank you, understand already.
Maybe this will help:
okay. whatever. from long ago, when i was a graduate teaching assistant (and i was teaching a lab), it was most often 0.6v for silicon.
well, your transistor curve is that of a function [itex]I_c[/itex] as a function of [itex]V_{ce}[/itex] for various [itex]I_b[/itex]. so given an [itex]I_b[/itex], you still don't know what [itex]I_c[/itex] is without also knowing [itex]V_{ce}[/itex]. the load line is another equation that relates [itex]I_c[/itex] and [itex]V_{ce}[/itex]. and that equation comes from the rest of the circuit (assuming no [itex]R_e[/itex]:
[tex]V_{cc} = V_{ce} + I_c R_c[/tex]
or
[tex]I_c = \frac{1}{R_c} ( V_{cc} - V_{ce} )[/tex]
plotting that equation on top of the transistor curves is your load line.
or
Understand.
when there is [itex]R_e[/itex] ,we can use the equation in this (transistor load line)
http://hyperphysics.phy-astr.gsu.edu/hbase/electronic/loadline.html
But for this case , our Ic=Ib, correct?
