Load resistance in voltage regulator
3 replies · 2K views
archaic
[/B]
I want to find the minimum resistance ##R_L## so as to maintain ##V_z##(voltage of the zener corresponding to the minimum current ##I_{z_0}##) across the same resistor ##R_L##.
I have two ways of looking at this, one of them is wrong and I need your help to figure it out!
First, I take off the diode as the load and find thevenin voltage, ##V_{th}=\frac{R_L}{R_l+R_s}V_s##, and since ##V_{th}=V_{R_L}## I'll equate it with ##V_z## which gives ##\frac{R_L}{R_L+R_S}V_S=V_z## thus ##R_L=\frac{R_S.V_z}{V_S-V_z}##
Second, If ##R_L##is minimal then ##I_L## passing through it would be maximal and ##I_{z_0}## minimal thus we'd have ##I_S = I_L+I_{z_0} \Leftrightarrow \frac{V_S-V_z}{R_S}=\frac{V_z}{R_L}+I_{z_0}\Leftrightarrow R_L=\frac{R_S.V_Z}{V_S-V_Z-R_S.I_{z_0}}##
(I'm skeptical concerning the implication ##I_L## maximal ##\Rightarrow## ##I_z## minimal, or in other words ##I_z = I_{z_0}##)
Thank you for your time!
The premises of your second attempt seem ok, but I can't understand how you can ignore the zener in your first attempt. There must always be a current at least IZ0 in the diode, so that corresponds to a resistance in parallel with RL equal to VZ/IZ0. I'd have thought you need to take that into account either as part of the load, or as part of the source.
Hm I guess instead of ##V_z## it should be ##V_z+r_zI_{z_0}## right? i.e I am considering the minimum Thevenin voltage for the diode to let current flow.
I assumed we were supposed to consider VZ fixed, since it looked like a constant
But if you wish to use a more accurate model of the zener, you have the right form.
The calculation with method 2 also seems to work out right.
I'm not familiar with the notation of the zener model, so whether the closer expression should be ## V_Z + r_Z I_{Z0} \ \ or \ \ V_{Z0} + r_Z I_{Z0} ## I don't know. This would be in the Data and Relevant formulae, I think.it won't make much difference
