Questions: How Far from Point P is a Given Line?
  • Thread starter Thread starter golb0016
    Line Point
A point P is located seven units from a straight line, and the problem asks how many points are both three units from the line and ten units from point P. Participants suggest visualizing the problem by drawing the line and point P to better understand the distances involved. The discussion reveals confusion about the number of intersection points, with some suggesting there are four and others concluding there are three. Ultimately, the consensus leans towards three points being the correct answer. The problem highlights the importance of interpreting geometric relationships accurately.
golb0016
A given point P is seven units from a given straight line. The number of points that are 3 units from the line and also 10 units from point P is: 1, 2, 3, or 4?
Not sure how to approach this problem.
Maybe you can draw it? Draw the line l and the point P.
What does the locus of all points with fixed distance to the line look like?
And all the points with fixed distance to the point?
Now find the intersects.
4, is this correct?
golb0016 said:
4, is this correct?
That's not what I would get but I may be interpreting the question differently than you. How did you get 4?
Actually I think it should be three. Two points to the side of the main point and one straight across.
Yes that's what I'm getting as well.
