Logarithms: (log8(x))^2 vs log8(x)^2
  • Thread starter chemistry1
  • Tags
    Logarithm
In summary, the conversation discusses the difference in notation between (log8(x))^2 and log8(x)^2. The consensus is that they mean the same thing, with the latter being ambiguous. The conversation also touches on the simplification of (log8(x))^2 and solving an equation involving logarithms.
chemistry1
108
Hi, quick question.
Is there a difference in notation when I say :
(log8(x))^2
and
log8(x)^2
Is it different or the same ? Thank you !
Mathematics news on Phys.org
I would say they mean the same thing. log8(x^2) would be different. To me, at least, log8(x)^2 means squaring log8(x). Hope that helps!
Well, I thought that saying log8(x)*log8(x) would be different than log8(x)^2
Ill keep waiting
Thank you
You can try it out on a calculator and see if there is any difference between (log8(x))^2 and log8(x)^2. :biggrin:
http://web2.0calc.com/
Yeah, it seems to say that it's the samething. COuld you try it on this one, I have doubts :https://www.mathway.com/
Thank you
chemistry1 said:
Hi, quick question.
(log8(x))^2
and
log8(x)^2
The first one is clear, but the second one is ambiguous. It could be interpreted as either (log8(x))2, or as log8(x2).
Parentheses should be used to make your meaning clear.
But with the first one could I say something like : 2*(log8(x)) ? ty
I don't see why not. What's in brackets is considered a single entity.
(log8(x))2 ≠ 2*log8(x) ! That's not how the log properties work.
loga(x2) = 2 loga(x). This isn't what you have in the first example.
See above.
Of course. :-p
As Mark44 said, just use parentheses to make things unambiguous.
- [itex](\log_8 x)^2[/itex] means one thing.
- [itex]\log_8 (x^2)[/itex] means another thing (which happens to be the same thing that [itex]2\log_8 x[/itex] means).
- Nobody is stopping you from writing [itex]\log_8(x)^2[/itex], but I wouldn't write it, because it's not crystal clear what it means.
Ok, but what is the meaning of : (log8(x))^2
is it (log8(x))(log8(x)) ?
Yes, this is clear.
And how would you simplify it ??
log8 x^log8(x)
Is this valid ?
log8 x^log8(x)
Is this valid ?
To me, this is the same as log8 (x^log8(x)), because you can only have a single input with the function log8.
Look, here's the reason why I'm asking the question :
(log8(x))^2+2(log(x))+1=0
I'm not able of finding a way to solve this. The closest answer I got was 1/64. Can somebody help me ?
Yes.
log8 x^log8(x)
Is this valid ?
Not if you mean (log8(x))2
Did you omit the base in the second term? Should it be log8(x)?
If so, your equation is quadratic in form. If you let u = log8(x), then the equation can be written as x2 + 2x + 1 = 0, which can be factored.
Mark44 said:
Yes.
Ahh... WEll... Thank you !
AH yes, I forgot it ! What do you mean by u= ... ?
Just replace log8](x) by u in your equation. The you have a true quadratic, not one that is just quadratic in form.
Solve the equation u2 + 2u + 1 = 0 for u, and then solve for x by undoing the substitution.
u^2+2u+1=0
(u+1)(u+1)=0 SOlution : u=-1
After I am not sure of understanding what you mean... Sorry xD
chemistry1 said:
u^2+2u+1=0
Since u = log8x, you have -1 = log8x.
chemistry1, keep in mind that a logarithm is an exponent on a particular base. For your equation, log8(x) is -1. This means that -1 is the exponent on the base (8) that produces x.
ok thanks, i solved it yesterday !
Related to Logarithms: (log8(x))^2 vs log8(x)^2
1. What is the difference between (log8(x))^2 and log8(x)^2?
The difference between (log8(x))^2 and log8(x)^2 is the placement of the parentheses. In (log8(x))^2, the logarithm is squared, while in log8(x)^2, the result of the logarithm is squared. This can lead to different values for the two expressions.
2. Which expression, (log8(x))^2 or log8(x)^2, should I use to solve a logarithmic equation?
Both expressions can be used to solve a logarithmic equation, but it is important to be consistent with the use of parentheses in the equation. If the equation already has parentheses around the logarithm, then use log8(x)^2. If there are no parentheses, then use (log8(x))^2.
3. How do I simplify the expression (log8(x))^2?
To simplify (log8(x))^2, you can use the logarithmic property loga(x^b) = b*loga(x). This means that (log8(x))^2 can be rewritten as 2*log8(x). Then, using the change of base formula, loga(x) = logb(x)/logb(a), (log8(x))^2 can be simplified to 2*log(x)/log(8).
4. Can (log8(x))^2 be written as log8(x^2)?
Yes, (log8(x))^2 can be written as log8(x^2). This is because of the logarithmic property loga(x^b) = b*loga(x). In this case, b = 2, so (log8(x))^2 is equivalent to 2*log8(x). This can then be rewritten as log8(x^2).
5. Is there a difference between (log8(x))^2 and log8(x^2)?
Yes, there is a difference between (log8(x))^2 and log8(x^2). In (log8(x))^2, the logarithm is squared, while in log8(x^2), the argument of the logarithm is squared. This can lead to different values for the two expressions, unless x is equal to 1 or 8.
  • General Math
  • General Math
9K
  • General Math
  • General Math
