MHB Calculating Logistic Growth Rate
To calculate the logistic growth rate, the equation X = AB^Y is relevant, where X represents the population and Y the year. The growth factor B can be determined using B = X2/X1 for successive years. A linear regression of log X against Y can help identify the relationship, but the significant jump in population in 2015 raises concerns about treating the data as logistic growth. This anomaly suggests the possibility of an error in the 2015 data, indicating that further investigation is needed. Understanding the cause of this spike is crucial for accurate growth rate calculations.
andre6051
I have a logistic growth problem. I know this because there is an upper limit of approximately 21,000 people. I need to calculate growth rate. Would it be something as simple as taking two populations and dividing them to get the rate (X2-X1/X1) to obtain it or is there an equation I am missing? I feel like the growth rate is harder to find than that. Plus, for some reason, the number shot up in 2015 and I don't know what to do. The only info I have is below. Thanks!
Example
X Y
44 2010
61 2011
79 2012
208 2013
326 2014
6663 2015
Mathematics news on Phys.org
Example
X Y
44 2010
61 2011
79 2012
208 2013
326 2014
6663 2015
Hi andre6051! Welcome to MHB! (Smile)
It looks like Y is a year and X increases exponentially.
So the relevant equation would be $X=AB^Y$ so that $\frac {X_2}{X_1} = \frac{AB^{Y_2}}{AB^{Y_1}} = B^{Y_2 - Y_1}$.
For successive years that means $B = \frac {X_2}{X_1}$.
It also means that $\log X = \log A + Y \log B$.
Typically we would find a linear regression between $\log X$ and $Y$ to figure out the relation.
Then again, as you already noticed, in 2015 the number shot up, causing an outlier.
We should get more information why that is, since it may mean we can't treat it as a logistic growth problem.
Can it be that the last X should really be, say, 663? Maybe there is a typo...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
