Looking for help calculating heat transfer for PEX ground loop project
The discussion revolves around calculating heat transfer for a closed loop water circulation system designed to prevent livestock water troughs from freezing. Participants explore various factors influencing heat loss, potential designs, and the feasibility of using solar power for the system.
  • One participant suggests calculating heat loss from the trough at the lowest expected air temperature, considering insulation and other factors like floating balls to reduce heat loss.
  • Another participant emphasizes the importance of understanding the ground temperature and the relationship between the circulating loop water temperature and the trough water temperature.
  • Concerns are raised about the potential risks of using a coil in drinking water, suggesting that external fittings may be necessary to avoid contamination.
  • Some participants express skepticism about the initial costs and maintenance of the proposed geothermal system, comparing it to electric immersion heaters as an alternative.
  • There are discussions about the placement of solar panels, with suggestions that they could also serve as an insulator for the trough if positioned correctly.
  • Participants mention the need for specific tank dimensions and insulation values for accurate calculations of heat loss.
  • One participant argues that burying pipe is more economical than running electric lines, citing the costs of freeze-proof waterers and the potential for a net zero footprint.
Participants do not reach a consensus on the best approach to the problem, with multiple competing views on system design, cost-effectiveness, and the practicality of different heating methods remaining unresolved.
Limitations include the need for precise tank dimensions, insulation values, and the worst-case ambient temperatures for accurate heat loss calculations. There is also uncertainty regarding the long-term reliability and maintenance of geothermal systems compared to other heating solutions.
mcantrell71
TL;DR
hydronic heat transfer calcs ??
Looking to build a suitable closed loop water (probably glycol mix) circulation system to prevent livestock water troughs from freezing. I assume that I need to calculate how much heat loss is predicted from the water tank in ambient air (varies, but assume worst case), then what length of heat transfer pipe will be required to be buried in stable ground temp (55 degrees?) to supply the necessary Btu's. The plan is to have a solar panel with battery to power circulation pump.
1/2" PEX. 0.675" OD, 0.070" wall
ground temp - 55 F
ambient - 0F
100 gallon trough uninsulated (for calculations)
0.5 - 1.0 gallon/min pump
THANKS FOR ANY INSIGHTS!!
Start by finding the lowest air temperature at which it needs to not freeze. Then calculate the heat loss from the trough at that temperature, then recalculate assuming insulation around the sides and under the bottom. If you can teach the livestock to poke their noses down through floating balls, calculate again with floating balls. Calculate heat loss assuming 32 deg F water in the trough. That heat loss is how much heat your system needs to supply.
Find the ground temperature in your area. The water temperature in the circulating loop will be roughly halfway between the ground temperature and the 32 degree trough water temperature. From the heat loss calculated above, and the temperature difference between trough water and circulating loop water, calculate the minimum flow rate.
Then search ground source heat pump. Look at the various methods of thermally connecting to the ground. Choose one. The easiest way to size the ground loop is to find the sizes of the ground loops for different size heat pumps, then interpolate based on your calculated heat loss.
Mount the solar panels above the water trough, so that on clear nights, the loss of heat to the cold sky above, does not increase the rate the water in the trough will freeze.
Arrange the solar panels, so any rain will clean the panel surface, then run into the trough.
I'm not sure I follow this. The solar panel is a PV panel to power the circulation pump for the ground loop. The trough has to remain open for animals to drink.
Thank you for the explanation. What I don't know how to do is run the calculations. I know it is not simple
Probably don't run the coil in the drinking water unless you want to poison them when it springs a leak? Unless perhaps the coil is a continuous loop of some plastic tube and the fittings are all external to the tank.
I started thinking about all the computational time, labor, material, and I suspect the initial cost of this system might have a 20 yr payback. Not to mention it's a potential maintenance nightmare. It seems like free energy but at what initial cost and annualized cost?
A friend had a geothermal system for their home, relatively new build. It sprung a leak somewhere in the ground coil. The general consensus among contractors...the system is a complete loss...get yourself a gas furnace.
Have you considered an electric emersion heater with a small circulation pump?
I did NOT suggest you put a lid made of PV panels on the tank.
On clear nights, the temperature of the sky above can be between -40 °C and -60 °C. That is why the water surface freezes quickly with a clear sky above. You need a roof above the tank to act as an insulator at the local air temperature. Obviously, it must not obstruct the animals and the panels must also be out of reach of the animals that might obstruct or chew on them.
In post #1, you show the panels as being mounted up high, away from the trough. Once you think about it, you will realise that if the panels are mounted above the trough, they can do the same thing as a roof.
Indeed, if you build a simple roof, you may find that the trough does not freeze, so you do not need the PV panels, pump or thermal transfer plumbing. Maybe all you need is an evergreen tree, protected from the animals, with foliage above the trough to hide it from the cold sky above.
In either case you will need (for the calculations):
1) The tank dimensions(length, width, height, and thickness), tank material, surrounding insulation R value.
2) Worst case ambient temperature for which you desire this to remain functional. The higher loss of either a calm,clear,cold night ( lower convection, higher radiation ), or a cold, windy, blizzard type conditions (lower radiation, higher convection)
I understand your perspective here....which is why i have done exactly that up until this point. I have about half of the materials to construct the system on hand already, and I will be trenching new water lines to various locations on my 160 acres. Burying pipe is WAY cheaper than burying electric, and my plan was to utilize a solar panel and battery to run the pump. A freeze proof livestock waterer runs about $400-800/each, and each needs electric. I'm pretty confident that the economics works out, plus it has a net zero footprint moving forward (disregarding the manufacturing of the materials involved).
IMO, That all depends on how much pipe you need for your heat exchangers, and the HP of the required pump to produce the desired flow rate, which is tied to the size of the solar panels, batteries that will inevitable become weathered/damaged and need replaced on some regular interval. Oh, and digging up frozen ground to fix a leak may not be as easy as you expect.
Anyhow, you need the information in post #9 to get started computationally. Do you have an engineering degree, because you are going to need one to figure this system out? between heat transfer rates, and flow rates I can promise you this will not be a trivial problem to work out from scratch.
I am still confused. When you say "roof", are you implying that it can be any height above the water surface (vs. a lid covering the tank)? A tank full of water in the barn (with a full roof overhead) freezes just as quickly as one outside.
Despite you discouragement, I will just build the system and see what performance i can achieve. Cheers
Not on a clear night. The tank outside freezes first.
I'm not trying to discourage you. Its what we do in engineering. You try to figure out whether or not its feasible before you build it. Changes to design on paper are relatively cheap, changes to implemented design are expensive.
Possibly, but they both DO FREEZE. Even tightly covered with a lid, I would assume they would freeze at 0 F
erobz said:
I'm not trying to discourage you. Its what we do in engineering. You try to figure out whether or not its feasible before you build it. Changes to design on paper relatively cheap, changes to implemented design are expensive.
If they use geothermal ground loops to temper housing in the thousands of square ft., Im sure keeping a 100 gallons of water from freezing is relatively easy.
Let me try another approach.
If i use a 1500w tank heater element to keep 100 gallons from freezing, and it is effective, how much heat transfer piping/flow is needed to achieve the equivalent of that 1500w?
Those systems cost $15,000 on average. That is after the design is fully functional. The actual engineering to design the systems probably took significantly more that the cost of a unit. This is in essence you are trying to do...design and build your own geothermal system.
Please, avoid glycol, it is corrosive to the pump and very toxic if the drinking water gets contaminated by accident.
Besides recommending biogas above (perhaps as a back up for coldest nights), I have found these links with some ideas that may interest you:
https://www.oakhillhomestead.com/2020/11/keep-livestock-water-from-freezing.html
That is a complicated question to answer. It's not a one-line computation...and then, its only half of the story because you need to get the heat into the system with another coil. A completely different set of computations.
The answer to your question is that depends on the working fluid, the thickness and material of the pipe, its length, diameter, to name just a few things.
If you cover the trough with a roof, the heating system will not have to do so much work. Since the clear nights are the coldest, that means a smaller heating system is needed for the worst case.
Why are you so resistant to arranging the panels to gain an improved economic advantage, especially one that requires no energy input. You will have to raise the panels anyhow.
pretty sure propylene glycol is harmless, and there would be no leak points inside a tank.
I am trying to avoid electricity. My most expensive electric bill last year was January--even higher than running the air conditioner in July. All because of livestock water
I am not resistant to anything. I do believe that you must be magnifying the perceived benefit of this "roof" quite dramatically. Besides, if you have worked with livestock (particularly goats), you soon learn that they will destroy anything they have the opportunity to do so.
Then do the calculations for heat loss to the sky on a clear night. Having a roof makes a big difference.
I have, but what has that got to do with the subject. I am not suggesting you lower the panels, so they can be damaged. I am simply suggesting you put them in a sensible place where they might do some good during the night.
well, most of that info was in post #1.
9K
  • · Replies 18 ·
17K
