What are some creative ways to harness wind power for a project?
The forum discussion centers on a project requiring the design of a wind-powered machine to pull a wooden block 4 meters towards a large industrial fan within 2 seconds. Participants suggest various creative solutions, including using a sail on the block, fluid dynamics with a tapered tube to accelerate air, and a pulley system with parachutes to enhance the pulling force. The block weighs approximately 0.5 to 0.75 lbs, and the fan has a diameter of 5 feet, generating a broad but not particularly powerful wind flow.
  • Understanding of basic physics principles, particularly force and motion.
  • Familiarity with fluid dynamics concepts.
  • Knowledge of mechanical systems, including pulleys and tension.
  • Experience with lightweight materials suitable for parachute construction.
  • Research fluid dynamics and how to manipulate airflow using tapered tubes.
  • Explore pulley systems and their mechanical advantages in wind-powered applications.
  • Investigate materials and designs for lightweight parachutes suitable for wind resistance.
  • Study the principles of sail design and how they can be applied to enhance wind propulsion.
Engineers, physics students, hobbyists interested in renewable energy projects, and anyone looking to innovate in wind power applications.
Phox
Ok so here's the deal. Wind powered machine project..
-Large Industrial Fan blowing
-4 meters away from the fan is a wooden block on the ground with a hook in it (to attach rope, etc)
-must pull the wooden block 4 meters TOWARDS the fan in the fastest amount of time possible
-machine must only be powered by wind. no stored energy, potential energy, etc.
-cannot lubricate the floor or put anything under the block
-no combustibles/other dangerous thingies :)
-to get an A, time must be 2 second or faster
So basically need to pull the block 4 meters TOWARDS the fan in the fastest amount of time possible using only the wind power of the fan.
I'm thinking I could always use the ol' windmill technique but I'd rather do something different. Any ideas?
The first thing you need to do is find a way to harness the wind energy as most efficiently as possible.
How heavy is the block, and how large is the fan? Could you simply put a sail on the block?
Phox said:
...need to pull the rope 4 meters towards the fan...
minger - are you trying to restart that 'sailing upwind' thread :wink:
The fan is probably 5 feet in diameter. It's a big fan however the wind coming from it is not as powerful as you might think. The wind is more... broad if that makes sense.. The block I'd say is .5-.75 lbs
And I don't really see the point of putting a sail on the block because yes, it'd be sailing upwind.
that shoots all my ideas to heck
how about a thin strong thread that gets caught in the fan blade and yanks the block into the fan
that always happens when its NOT supposed to...
dr
dr
Haha, unfortunately against the rules. That was my first idea ;)
I can't understand how something could move up the stream of wind. To me the challenge is how to increase the momentum of the air particles so by conservation the block will have to move in the other direction. but the real life effect of drag would always push it back.
Perhaps you could somehow take advantage of fluid dynamics to speed up the air. I am thinking a tube with a large end toward the fan and a small end at the back. This way the air would be moving faster out of the small end. But the drag would definitely push it back even if any force was gained. Maybe a lot of lubrication in the tube?
Hmm. Perhaps I didn't explain this well enough. I can make some kind of machine directly in front of the fan to harness the wind and to pull the rope + block towards the machine and fan.
Oh yeah, I had the wrong idea. Well you could put some sort of pulley supported by two stabilized legs in front of the fan. the rope would have a parachute on one end and the block on the other. the fan will start and the parachute will be blown back. to increase time you could attach other parachutes at periodic lengths along the rope, so when they go across the pulley they deploy, so the force doesn't die out.
This might be a good idea. How would I make the parachutes?
Hmm. I think they would have to be very light so they deployed easily. Possibly you could make them out of grocery bags. It really depends on how powerful the fan is, i could just see some of the parachutes sitting there and not opening up at all.
  • · Replies 24 ·
