Low noise 60 Hz notch filter circuit
The discussion centers on designing a low noise 60 Hz notch filter circuit that minimizes attenuation above 100 Hz. A recommended solution is the Burr-Brown active notch filter, which includes separate low-pass, band-pass, and high-pass filters that can be combined using a summing amplifier. Participants suggest considering alternative methods to eliminate 60 Hz noise coupling before filtering, such as modulation techniques. The focus is on achieving a sharp notch filter without compromising higher frequency signals.
  • Understanding of active filter design principles
  • Familiarity with Burr-Brown filter applications
  • Knowledge of summing amplifiers
  • Basic concepts of signal modulation techniques
  • Research Burr-Brown active notch filter design specifications
  • Explore summing amplifier configurations for filter applications
  • Learn about signal modulation techniques to avoid 60 Hz interference
  • Investigate low noise circuit design practices for audio applications
Electronics engineers, audio engineers, and hobbyists focused on designing low noise filter circuits for audio applications, particularly those dealing with 60 Hz interference.
m718
Does anyone have a very low noise 60 Hz notch filter circuit that will not attenuate over 100
or a low noise bandpass from 100 to 20000 hz .
You want a sharp notch to supress 60Hz and not attenuate 100Hz?
A better approach might be to eliminate the 60Hz noise coupling first, so that it doesn't show up in your signal channel. And/Or, do something with your signal to move it away from 60Hz (modulation, etc.).
What is your application?
  • · Replies 46 ·
