Low pass filter for 60Hz rejection
In summary: Rectifier can convert AC into DC but I am not looking for that. In other words, I am not looking to convert AC into DC by LPF.Rectifier can convert AC into DC but I am not looking for that. In other words, I am not looking to convert AC into DC by LPF.
pjshah72
Hi All,
I am looking to design LPF with Inductor and Capacitor that can reject 60Hz frequency.
I tried on google about the same but did not get an idea.
Basically, I am trying to do is this, Incoming mains (AC Signal) has 60Hz frequency and I wanted to make it like a DC (close to DC) which has no frequency.
Can I do with LC-LPF?
Any help and advise will be greatly appreciated.
Thank you!
The mains voltage has no DC-component (ideally), so you won't get anything from a low-pass filter. What you're looking for is a rectifier:
http://en.wikipedia.org/wiki/Rectifier
The diode-bridge is very common:
http://en.wikipedia.org/wiki/Diode_bridge
You shouldn't be messing with mains voltage if you have no experience with high-voltage applications. It's an easy way to get yourself killed.
I want to make filter that gives me close to zero frequency when I applied AC (mains).
I want to chop AC frequency to none (close to zero).
Thank you!
Let's think the other way. How can I make LC-LPF filter that can reject 60Hz? (not considering this for AC signal.) Assume this is a frequency of some signal.
You could use a low-pass filter with a suitable break frequency to attenuate your 60 Hz component, but that would impact everything above 60 Hz aswell. Have you had a look at a notch filter?
http://en.wikipedia.org/wiki/Band-stop_filter
You can find tonnes and tonnes of practical guides to building them with a search on Google.
One traditional and simple way is with a passive twin-T notch filter.
http://sim.okawa-denshi.jp/en/TwinTCRkeisan.htm
You will have to build it using high voltage capacitors and resistors.
When the power turns on or off there will be a big spike on the output.
The signal that passes will be the harmonics of 60Hz, synchronous noise from rectifiers and any signalling on the line.
What are you going to do with the signal once you have removed the 60Hz from it?
I am very new in this field (2nd year) so I don't know much. If I will remove 60Hz successfully then I will feed to Voltage regulator and try to get some specific voltage out of it. (for ex. 12V out of voltage regulator.)
Thank you!
pjshah72. You are building a 12V DC linear power supply. You will need a power transformer, a bridge rectifier and a storage capacitor. You do not need a 60Hz filter, the storage capacitor will do that.
The rectified secondary voltage will have a frequency of 120Hz.
Hi Baluncore,
Thank you for the input. I wanted to try the other way. With transformer and bridge rectifier with storage capacitor is common method. I want to try only.
Thank you!
If you remove the 60Hz component of the signal coming from the mains you won't have any signal left at all. (Ideally, of course)
If your 60Hz signal had some sort of DC bias imposed on it (which it currently doesn't), then you could filter out the 60Hz portion and just extract only the DC bias at the output of the filter.
Like many others have suggested, in order to achieve what you've described you'd want to use is a rectifier circuit, not a filter.
Likes 1 person
Got it! Thank you all for the responses.
How to calculate voltage that comes after this filter circuit? (Input is AC mains.)
I am looking for formula or method.
Thank you!
To generate DC from an AC source you must perform a multiplication such as a square. A rectifier diode is non-linear and so it generates the DC offset you need.
If you full wave rectify the 60Hz AC you will have a signal with a fundamental at 120Hz but with a DC offset.
Now imagine you used an active low pass filter to remove that 120 Hz and another for each of it's significant harmonics. The power available at the output of the active filter would be derived entirely from the power supplies of the active filter. This defeats the purpose.
By using passive resonant LC notch filters for the 120Hz fundamental and most significant harmonics, then followed that by an LC low pass filter you would have built a smooth DC power supply. Only asynchronous noise would reach your DC supply rail.
Can anyone suggest value for L and C to reject 60Hz frequency?
I did google but all is about only diagram.
You are looking for trouble!
Never connect a circuit you build to the mains, it is dangerous and what you have in mind won't do what you think it will.
You need to study a lot more before you understand the hazards of mains electricity and how circuits work.
bold by me
I totally agree with
Wouldn't it be better to understand how it's done in the real world instead of killing yourself? Do you know how a bridge rectifier works? If not, it's fairly simple as this image shows:
Image compliments of http://educypedia.karadimov.info/electronics/javaanalogsemipassif.htm
What is the safe way? Can I put transformer between AC and circuit so it will step down voltage?
Thanks for the image!
yes that's the safe way
Dave
Likes 1 person
I'll put it a different way (this hurts my head). The AC mains have 1 frequency: 60 HZ. If you filter that out (which is not advised) you have no voltage of any kind. Zero. Nada. It does not magically appear as some other frequency or voltage. Do you understand that?
You would have to dissipate the energy while dropping the line frequency from 60 Hz to 0 Hz.
Here's some energy being dissipated.
https://www.youtube.com/watch?v=4bBvmPRqfmo
hey Don
That's pretty horrific, huh
Dave
Even that is not safe, until you understand more about the circuit you connect it to. You are considering using an inductor in your filter. Inductors can generate a high voltage by themselves, and in conjunction with a capacitor, can produce a lethal voltage. All that is needed is a slight rearrangement of connections and you could end up with hundreds of volts where you thought there would be only 10volts. Keep studying and doing the experiments that your course provides for you, they should at least be safe!
Always, caution!
Thank you everyone for alert!
i will study and learn before practical!
Everyone else has said what I'm about to say in different ways. Maybe this will strike you a bit differently.
The AC mains are 60Hz AC and have an average voltage of 0. That is, there is no DC. When you filter out the AC, there is nothing left. Your filter blocks all the AC. It doesn't transform it. Filters are linear.
Rectifiers are non-linear, so they can transform it.
If you put AC through a full-wave rectifier, you have now created a non-zero average voltage equal to the Peak voltage times 0.707. Now, if you filter out 60Hz, you would have DC remaining.
Linear power supplies go through a transformer and are rectified and then filtered and possibly regulated. Switching power supplies do a bit more.
can you explain for SMPS in detail too?
Thank you for the explanation!
Not quite.
A full-wave rectifier is a frequency doubler. There would be no 60Hz fundamental to remove with a notch filter.
A full-wave rectifier would generate a DC offset, with a 120Hz fundamental and many harmonics of 120Hz. If you removed the 120Hz fundamental you would be left with DC plus many even harmonics of the missing 120Hz fundamental.
A half-wave rectifier would produce a DC offset, with a 60Hz fundamental and many harmonics.
@Baluncore
You are absolutely correct of course. I was intentially being overly simplistic and ventured into WRONG. I didn't want to get into power supply filters, And I added the full wave as a simple correction after noticing that .707 was wrong for half wave.
@pjshah72
Use wikipedia and google to explore SMPS. If you then have specific questions, come back. But first, explore transformer based linear power supplies ( full and half wave) and center-tapped transformers. Find out about the output voltage, ripple, and load characteristics of the different supply architectures, and the different filtering methods.
Likes 1 person
Related to Low pass filter for 60Hz rejection
What is a low pass filter?
A low pass filter is an electronic circuit that allows low frequency signals to pass through while blocking or attenuating high frequency signals. It is commonly used to remove unwanted noise or interference from a signal.
Why is a low pass filter used for 60Hz rejection?
The 60Hz frequency is commonly associated with electrical power lines and can cause unwanted interference in electronic circuits. A low pass filter with a cut-off frequency of 60Hz can effectively remove this interference from a signal.
How does a low pass filter work?
A low pass filter works by using a combination of resistors, capacitors, and inductors to create a frequency-dependent voltage divider. This allows low frequency signals to pass through with minimal attenuation, while high frequency signals are attenuated or blocked.
What is the cut-off frequency of a low pass filter?
The cut-off frequency of a low pass filter is the frequency at which the filter begins to attenuate the signal. In the case of a 60Hz rejection filter, the cut-off frequency would be 60Hz.
Are there different types of low pass filters for 60Hz rejection?
Yes, there are different types of low pass filters such as passive and active filters, as well as different filter designs such as Butterworth, Chebyshev, and Bessel. The type of filter used may depend on the specific application and desired performance.
  • Electrical Engineering
