Lower and upper limits for a volume integral
The discussion focuses on determining the lower and upper limits for a volume integral in classical mechanics. The user calculated the x value based on symmetry, arriving at limits of -az/2h and az/2h. They referenced a linear function f(z) that decreases from 1 to 0 as z varies from 0 to h, suggesting a relationship with the geometry of the problem. Additional insights include deriving the limits from the equation of a line, emphasizing the slope and intercepts relevant to the integral's boundaries. The conversation highlights the importance of understanding geometric relationships in setting integral limits.
chrisyuen
I read an e-book about the classical mechanics and didn't know how to find the lower and upper limits for a volume integral.
Perhaps, it may be related to the use of similar triangle.
I calculated the x value only (y is the same as x because of symmetry)
z/h = x/(a/2) = 2x/a
x = az/2h (distance)
Lower Limit = -az/2h
Upper Limit = az/2h
Can anyone tell me how to obtain the same values as the one given by the author?
Thank you very much!
f(z) = (1 - z/h) is a function that goes linearly from 1 down to zero as z goes from 0 to h:
z = 0 --> f(z) = 1
z = h --> z/h = 1 --> f(z) = 0
Multiply by the desired width at the base (a/2) and you've got a line that goes from x = a/2 when z = 0, to x = 0 when z = h.
You could also derive it from the equation of the line.
y = mx + b, with m = slope and b = y-intercept.
The right-hand line intercepts the y-axis at h, and the x-axis at a/2. So the slope is m = -2h/a, and b = h. Plug those into the equation and solve for x in terms of z.
  • · Replies 20 ·
