Ltspice - divided two plots from different run simulations
To divide two plots from different LTspice simulations, exporting the data to a separate graphing application may be necessary, as LTspice does not support simultaneous displays from different simulations. Joining the LTspice user group can provide additional resources and support for specific questions. Online guides are also available for further assistance. Engaging with the community may yield more tailored advice. Utilizing these resources can enhance your simulation analysis experience.
arielkool
Hi,
I have a plot of v(onoise) of my circle using noise simulation.
I also have my V(output) from my ac frequency analysis. How do i divide between the graphs?
Maybe @Baluncore can advise? He does more LTSpice than most of us. There are also online guides.
I doubt that it supports simultaneous displays from different simulations. You'll probably have to export the data to another graphing application.
Welcome to PF.
I would suggest you first join the LTspice group, then search and ask your specific question there.
https://groups.io/g/LTspice
Likes berkeman and DaveE
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
