M-ary Tree: Given Nodes, find leaves
  • Thread starter Thread starter scorpius1782
    Nodes Tree
In a 4-ary tree with 173 nodes, determining the number of leaves involves calculating the distribution of nodes across levels. The first four levels can accommodate a maximum of 85 nodes, leaving 88 nodes for the fifth level. Since not all nodes in the fourth level can have children, some must be leaves. The discussion highlights that by counting nodes at each level and understanding the limitations of the tree structure, one can derive that a portion of the fourth level nodes are leaves, along with all nodes in the fifth level. This approach emphasizes the importance of systematic counting and understanding tree properties to solve such problems.
scorpius1782
(I'm struggling with trees now so I expect to have a lot more questions on here like this)
I have a 4-ary tree with 173 nodes. How many leaves do I have?
So I know that each node, if it is not a leaf, will have 4 nodes coming off of it (stated in problem). It seems to me that there should be a quick and simple way to do this... but I can't figure it out. Like all of these other problems I can't simply draw the trees and expect to be able to count without being 100% sure I didn't make a mistake. Or even have it drawn and turned in on time since they can be quite large...
So, I tried simple examples. Say only 2 of the first 4 shared it, then: 1+4+2*4+8*4+32*4=173. Well, I know that at height 1 there are 2 leaves. Height 2 there are no leaves.. and at height 4 they must all be leaves. Therefore, there are 2+32*4=130 leaves.
I believe I'm right but is there a simpler way to do this??
I don't understand what you're doing, so I don't know if the number you got is correct. Counting the nodes seems more to me like adding a finite series.
Top level (root) : 1 node
2nd level: 4 nodes
3rd level: 16 nodes
4th level: 64 nodes
5th level: 256 nodes
For each node in a given level, there can be up to 4 nodes below it. At each level, the number of nodes would be four times the number of nodes in the previous level. In the top two levels there are 5 nodes in all. In the top three levels, there are 21 nodes in all. In the top four levels, there are 85 nodes in all, and so on. Since there are fewer than 1 + 4 + 16 + 64 + 256 nodes, the fifth level can't be full, so some of the nodes in the fourth level must be leaves, not nodes.
That's how I would approach it.
I started the problem this way but couldn't figure out how I could simply get the number of leaves. I mean, some of the 4th level clearly have leaves but I have no idea how many. That is why I resorted to examples.
From the root through the 4th level there are 85 nodes. How many more nodes do you need to get to a total of 173 nodes? The remainder have to be in the 5th level. Some of the nodes at the 4th level will necessarily turn out to be leaf nodes.
173-85=88, so 22 nodes in level 4 have children and 44 are leaves. 44+88=132. That's too many, I think. Have I made a mistake?
No, 22 nodes in level 4 have children (4 apiece) and 42 of the nodes in level 4 are leaves. All 88 of the level 5 nodes are leaves.
Mark44 said:
No, 22 nodes in level 4 have children (4 apiece) and 46 of the nodes in level 4 are leaves. All 88 of the level 5 nodes are leaves.
But, that would make 68 nodes in level 4.
I wrote 46, but meant 42. It was pretty late when I wrote that. It is now corrected in my earlier post.
Okay, I just noticed my mistake as well. Thats what happens I write on my phone as I'm falling asleep in bed. Thanks for the help
The answer here is less important than the technique I used, which was pretty much just counting how many nodes there were at each level, and the running totals for the levels. Since you had 173 nodes, and levels 1 through 4 accounted for a total of 85 nodes, and levels 1 through 5 could have at most 341 nodes, the 5th level couldn't be completely filled. The rest was just figuring out how many nodes in the 4th level could be nodes, and how many could be leaves.
