Magnet in a AC current solenoid
3 replies · 3K views
sgstudent
when you place a magnet into a solenoid with a ac current it will get demagnetised. So does this mean that the magnetic field will go into the magnet in the opposite direction of the magnet's own magnetic field? and disalign it. meaning will the magnetic field enter the magnet as though it is like another piece of iron?
thanks for the help!
A rapidly alternating mag field will dis-arrage the mag-wessels. hence deenergising the same.
Perhaps it's easier to consider the magnet as a large number of atoms. Since electron and protons have very small dimensions, most of the atom is empty space ( vacuum). So, the magnetic field "enters" the magnet. The filed there applies toque on electron magnetic dipoles.The torque doesn't simply rotate the dipole to get parallel with the field but it initially cause precession. the precession damps usually after a short time ( in order of nano-seconds) and the new alignment would be parallel with the applied field ( assumed strong enough to case the reversal)
This link,
http://www.google.com/url?sa=t&rct=...rey3Dw&usg=AFQjCNGKy8swuzdp-t8dpWyhgMX3vsrpTg
on page 27 & 28 (PDF pages 29 & 30) speaks to demagnetizing of transformer cores that have retained magnetism.
They have a different shaped B-H curve than your permanent magnet but principle is same.
If thet link doesn't work, search on : ittechinfoappguide.pdf
and pick this one: www05.abb.com/global/scot/scot235.nsf/.../ittechinfoappguide.pdf
