Magnetic field due to semi-circular wire
5 replies · 15K views
ks_wann
So, I've got a wire with a semicircle about the origin, my task is to find the magnetic field at M=(0,0,z).
I want to use Biot-Savart, so I find dl', r and r-hat. (r being the vector from the source point to field point)
\begin{equation}
r^{2}=R^{2}+z^{2}\\
\mathbf{r}=R\cos{\theta}\mathbf{\hat{i}}+R\sin{\theta}\mathbf{\hat{j}}+z\mathbf{\hat{k}}\\
d\mathbf{l^{\prime}}=Rd\theta \mathbf{\hat{\theta}}
\end{equation}
With these identified, I use biot-savart:
\begin{equation}
\mathbf{B}(\mathbf{r})=\frac{\mu_{0}I}{4\pi}\int\frac{d\mathbf{l^{ \prime}}\times\mathbf{\hat{r}}}{r^{2}}
\end{equation}
What troubles me is the cross product. I get
\begin{equation}
d\mathbf{l^{\prime}}\times\mathbf{\hat{r}}=\frac{R}{\sqrt{R^{2}+z^{2}}} \mathbf{\hat{\theta}}\times(R\cos\theta \mathbf{\hat{i}}+R\sin\theta \mathbf{\hat{j}}+z\mathbf{\hat{k}})
\end{equation},
and I'm not sure what to make of it as the unit vector would change all the way through the semicircle.
This is a case where the angle between [itex]\vec{dl'}[/itex] and [itex]\hat{r}[/itex] is always the same so it is much better to simply use the right hand rule to find the direction and use [itex]dl' \, \sin \theta[/itex] to find the magnitude. If you absolutely want to use a cross product, write instead [itex]\vec{dl'}[/itex] as [itex]dl' \, \hat{\theta}[/itex].
Okay. So I basically just state that the field points downwards in the case of z=0, and get
\begin{equation} \frac{\mu_0I}{4\pi} \int_{\theta_{1}}^{\theta^{2}} \frac{R}{(R^2+z^2)^{3/2}} \sin{\theta} d \theta \end{equation}?
What about the change in direction with increasing z?
Consider a small segment of the wire of length ##d\vec l##, producing a small magnetic flux density ##d\vec B## at position ##\vec r## away from the wire.
Hint: what can you say about the direction of ##d\vec l## and ## \hat r##?
Also, expressing ##dl = R \space d\phi## will make your integral much easier. Exploit symmetries instead of diving straight into Cartesian cross products..
Well, ##d\vec l ## and ##\hat r## are perpendicular at all times. I see that for a full circle, all the horizontal components will cancel, thus giving me ##B(z)##. Am I missing something?
I'm sadly not very good at identifying and exploiting symmetries..
Yes horizontal components cancel for a full circle, but not for a semi-cricle. Do the integration for horizontal and components separately.
