Magnetic Field From Coiled Wires
Solenoids are designed as coils of thin copper wire with dielectric separation to optimize magnetic field generation and manage current flow. Using a solid copper cylinder might reduce resistance, but it would not create the desired magnetic field direction, as current would flow straight through rather than spiraling. The coiled structure allows for controlled magnetic field orientation, essential for applications like electric motors. The design also helps in managing heat and maintaining efficiency. Overall, the coil configuration is crucial for effective magnetic field generation in solenoids.
KrizG
I'm just curious why solenoids used to create a magnetic field, such as those used in electric motors are typically coils of thin copper wires with a dielectric separating each turn of wire instead of using a single cylindrical shell made of solid copper. Wouldn't using a cylinder shell made entirely of copper be more effective? Because of the decreased length, there would be much less electric resistance, and I believe the magnetic field would remain the same if the current density flowing through it were the same.
In a solenoid, the current flows in circles, slowly spiraling towards the other side. How can you get that behavior if you used a cylinder? The current would just move straight through, and then you get a magnetic field that's not in the direction you want.
It may be shown from the equations of electromagnetism, by James Clerk Maxwell in the 1860’s, that the speed of light in the vacuum of free space is related to electric permittivity (ϵ) and magnetic permeability (μ) by the equation: c=1/√( μ ϵ ) . This value is a constant for the vacuum of free space and is independent of the motion of the observer. It was this fact, in part, that led Albert Einstein to Special Relativity.
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
