Magnetic field inside and outside the rectangular conductor
The discussion centers on calculating the magnetic field generated by a DC current in a rectangular transmission line using finite difference methods. The user is implementing a MATLAB code based on the equation curl curl A = µ J, with the condition div A = 0, and is facing issues with the results, suspecting boundary conditions may be the cause. They are using symmetry planes to simplify the problem to a quarter conductor. A suggestion is made to apply Ampere's law and model the current as a sheet current for a more straightforward approximation. The conversation highlights the challenges of numerical modeling in electromagnetic fields.
merro
Hi
I want to find the magnetic field result from DC current flow through the rectangular transmission line numerically by using the finite difference.
the solved equation is curl curl A =µ J , with div A=0, and J is a uniform current on the crosssection.
I implement the MATLAB code , but the result is not logical, so i think the boundary condition is the problem
I take the symmetry plans , one vertical and other Horzi. and solve the problem for quarter conductor.
my question the boundary conditions for that problem
thank you in advance
Couldn't you just use amperes law and model it as a sheet current, at least that would give you an approximation.
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
Hello dear reader, a brief introduction: Some 4 years ago someone started developing health related issues, apparently due to exposure to RF & ELF related frequencies and/or fields (Magnetic). This is currently becoming known as EHS. (Electromagnetic hypersensitivity is a claimed sensitivity to electromagnetic fields, to which adverse symptoms are attributed.) She experiences a deep burning sensation throughout her entire body, leaving her in pain and exhausted after a pulse has occurred...
