Magnetic field produced by linear current in COMSOL
Caleydos
TL;DR
Issue with COMSOL 5.5 when trying to calculate the magnetic field produced by linear current in 3D
Hello,
I have used an edge current of 10 A through a 0,45 cm (lenght) wire inside an air sphere. The thing is that, according with Ampere law, the magnetic field (B) produced at a 1 mm of distance from the wire shall be 0,002 T, and I am obtaining much higher values in this simulation (around 0,3 T at his point).
I have done it in 2D and result is OK, according with theoretical values, but I do not know why in 3D it changes. Any idea please?
Many thanks in advance
  • COMSOL multislice plot of magnetic flux density norm in tesla, shown as a colour map with a colour bar from 0 to about 0.28, with the highest values in red at the centre and blue at the edges.
Sure! I attach them here. Thanks a lot!
First one is the 3D model (lateral view), showing the value of the magnetic flux density in COMSOL 5.5 (this value do not matches with theoretical)
The second one is 2D in COMSOL 3.5, this value really matches with theoretical
  • COMSOL multislice plot titled "Magnetic flux density norm (T)" showing a circular cross-section with a blue ring and a central red-to-blue colour gradient, scale 0 to 0.1 T, with an evaluation table of x, y, z and values below.
    Flujo campo en modelo 3D (esfera 20 cm). 0,1 T a 2 cm del centro del conductor.png
  • COMSOL Figure 2 plot of magnetic flux density norm in T against arc-length, rising linearly from 0 to a peak near 3.9 x10^-3 T at about 0.5 x10^-3, then falling to about 2 x10^-3 T at 1 x10^-3, with concentric contour rings of magnetic flux density behind it.
Thanks a lot for your reply.
This is one of the things that I supossed in the beginning, but I made the boundary sphere wider and the result is the same (see attached). It seems the magnetic flux shown in the boundary layer is debt to the sphere is very small. Any other idea?
  • COMSOL multislice plot titled 'Magnetic flux density norm (T)' on a blue circular field, with a colour bar from 0 to about 0.25 T; the field is brightest at a small spot at the centre and fades quickly outward.
I have tried modifying the length of the wire, magnetic flux should remain the same, but it isn´t. It seems the longer wire produces more flux at 1mm (it makes no sense).
On the other hand, I do not understan why this shape in the magnetic flux, it should be purely circular.
  • COMSOL multislice plot of magnetic flux density norm in tesla, shown as a blue field with a small bright red-yellow spot at the centre, with a colour bar from 0 to 0.25 T and x and z axes.
  • COMSOL multislice plot of magnetic flux density norm in tesla, colour scale 0 to about 0.25, showing a red and yellow triangular high-field region around the centre on a blue background.
